07-20-2018, 04:29 AM | #21 |
Re: Ring size availability
Be sure to correct the orientation of the pin retainer clips. One I see pictured is wrong.
07-20-2018, 08:33 AM | #22 |
07-20-2018, 10:37 AM | #23 |
Now I see what you guys are talking about
07-20-2018, 08:44 PM | #24 |
07-21-2018, 07:02 AM | #25 |
I've built several engines with 3 7/16 bore one for the track and ine for the street. The street engine was built over 30 years ago and is still running. I used 21Z rods on the stroked crank.
07-21-2018, 07:17 AM | #26 |
Gary |
07-21-2018, 07:21 AM | #27 |
JWL wants you to put the circlip gaps at either 12 or 6 o'clock. A must with high revving engines
07-21-2018, 07:30 AM | #28 |
^^ that's a new one for me, I didn't know that. I learnt something today.
Good luck with the new motor. It's a biggie. Mart. |
07-21-2018, 09:02 AM | #29 |
With the gaps the way they are now, it is possible for them to compress and possible come loose.
07-21-2018, 10:07 AM | #30 |
Thanks for the info....Im used to using Spirolox, good stuff guys. Ron, can you remember how you cammed the street engine?
This will be going into my cut down Deuce roadster eventually. BFD Last edited by Blownflatheaddeuce; 07-21-2018 at 10:34 AM. |
07-21-2018, 01:47 PM | #31 |
Cool roadster!!!!
07-22-2018, 06:05 AM | #32 |
I know one had an Isky 1015 in it the other probably a 400jr for the track. But that was along time ago.
07-22-2018, 03:41 PM | #33 |
So far I have had two complete 3 7/16 bore by 4 inch stroke Flatheads never tried to run one. I still have one complete engine available everything is in a 59A block anyone interested send me a PM.
Ronnieroadster
I use the F word a lot no not that word these words Flathead , Focus and Finish. "Life Member of the Bonneville 200 MPH Club using a Ford Flathead block" Owner , Builder, Driver of the First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 in one and a half miles burning gasoline. First ever gas burning Ford flathead powered roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH |
