01-18-2018, 12:43 PM | #1 |
Steering box Id.
Good evening. My names Stephen I'm from the UK.
I'm currently building up a Model a chassis and i brought a steering box and told it was off a model A. I've stripped as it doesn't hold its oil and I hated the color it was painted I require a gasket kit as previous it was shimmed with gaskets on the bottom for the input shaft. unfortunately I'm not 100% sure that it is a model a steering box thanks to google. issue is I can't find it if I google the part Numbers off it. on the steering box stamped on the main body is CRTAAF 3550-A Ingersoll Machine on the side of the steering box where the adjuster is this is stamped CRTAAF 3580-A attached some pictures Thanks Stephen |
01-18-2018, 12:45 PM | #2 |
Re: Steering box Id.
Doesn't resemble any Model A or AA that I have seen
01-18-2018, 12:50 PM | #3 |
ill post some more pictures of the insides as well.
01-18-2018, 01:33 PM | #4 |
Never seen one like that.
"That's my wild unsubstantiated guess, and I'm sticking to it regardless of the facts!" |
01-18-2018, 01:40 PM | #5 |
Seems someone else has had one too...
https://www.fordbarn.com/forum/showthread.php?t=128075 https://en.wikipedia.org/wiki/Ingersoll_Machine_Tools Maybe Canadian: https://www.ford-trucks.com/forums/1...ering-box.html
1931 Murray Town Sedan. Black body with Apple Green pin stripe. 1923 Model T Touring with electric start. Low radiator Cincinnati, Ohio |
01-18-2018, 02:31 PM | #6 |
If so, the box looks very similar to a right hand drive F100 box. |
01-18-2018, 02:49 PM | #7 |
Thanks for the replys. well spotted it it is a RHD steering box.
01-18-2018, 03:42 PM | #8 |
few more pictures of the internals and pitman arm
01-18-2018, 03:50 PM | #9 |
Pitman arm
01-18-2018, 03:58 PM | #10 |
That Pitman Arm looks made up. JMO.
01-18-2018, 04:05 PM | #11 |
internals
01-18-2018, 04:06 PM | #12 |
Thanks for all the reply's, appreciate the help I've been a contact for a guy who rebuilds and mods steering boxes so if I find out what it is I shall let you all know. unless anyone else responds thanks
