07-04-2016, 02:37 PM | #1 |
What size jets ?
My '40 runs really rich as I have black soot coming out the tail pipe at start and I get poor gas mileage.
What size jets are recommended for 85hp - '40 and is there something else I can do to lean it out ? Thx....Mike |
07-04-2016, 04:04 PM | #2 |
Re: What size jets ?
Could be just a bad Power valve.
07-04-2016, 05:06 PM | #3 |
07-04-2016, 07:01 PM | #4 |
Should be around 51 main jets.
07-04-2016, 07:08 PM | #5 |
51 jets, but I think you'll find the power valve is carput. Walt
07-05-2016, 08:25 AM | #6 |
Thx....Mike |
07-05-2016, 08:50 AM | #7 |
Check with CharlieNY on this site. Has machined PV's that's seat properly.
07-05-2016, 12:03 PM | #8 |
Thx Chap....
07-05-2016, 12:07 PM | #9 |
Type this into google:
running rich site:www.fordbarn.com Lots of posts here for 94s running rich. I have typed out the long list of things that can cause it many many times. Once only recently. This was it: https://www.fordbarn.com/forum/showthread.php?t=197943 Lots of things to check before changing jets. Mart. |
07-05-2016, 01:03 PM | #10 |
Thx Mart
07-07-2016, 09:01 AM | #11 |
Yeah, you are at or close to sea level, so #51 jets should be just right for you altitude. Must be something else causing rich condition.
07-07-2016, 01:52 PM | #12 |
You might try a company called Renners Corner. They only advertise '28 to '34 but they might be able to help. All the jet's that I had purchased before Renners were JUNK. If you check them with a pin gauge they weren't even close. Renners flow tests every jet and gives you a paper showing the results. You can't ask for better service.
07-08-2016, 01:52 AM | #13 |
Thx woodie I'll give them a try along with new power valve.
Mike |
