Old 12-26-2010, 05:49 PM   #61
pooch
pooch's Avatar
Default Re: 1930 Ford Sheetmetal Work
Yo Flop, I have been in the sandblasting game for 35 years. so that is why I cringe at disc sanding panels.
That coupe paint looks pretty good.
I take it you do not have a sandblaster and I figure your old sand paper is clogging with paint and causing heat before you get to metal, as well as the sand marks in panel..
Try a heat gun and a sharp putty knife to melt paint off.
Then if you must, it will be a very light lick over with 120 grade.
Get a 2 inch wide putty knife and cut it back to about 1 1/2 inches LONG and round the edges off, so it is short and very stiff.
Heat the paint and you will know when it gets soft enough to peel off in sheets, way before any excess heat will warp panel.
Start on an angle with knife under paint and blow heat forward and keep going.
You would do that 1/4 panel in about 15 minutes.
Thick paint is best for heat, not so good with thin paint.
Some types of paint don't react too well to heat, then you must resort to stripper if you do not have a blaster.
If I have to strip a panel smooth, no blast profile for paint tooth, I run over with an orbital sander with worn out 36 grit.
Gives a perfect tooth for primer.
Here is one of my old videos. I will make a better one next time I have to blast and get dirty.
(apologies for work behind hand a bit, because I was holding cam with one hand while blasting and thinking the lens was getting peppered.
I will cover the cam with plastic next time for a better view).
pooch is offline   Reply With Quote
Old 12-26-2010, 06:04 PM   #62
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Wow Pooch, ...maybe it was a good thing your hand WAS there to protect the camera lens from ricocheting media!! I DO agree with your assessment regarding stripping using a disc.
One thing in FLOP's defense regarding the paint stripping is when doing a customer project, often times the 'how', --or 'what' he wants to do it is not an option. There are things we do that might cause others to question why we did it that way when the true answer is either we did not have the budget to do it the proper way, ...or the customer did not want it done that way.
30cab, check for a PM.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 12-26-2010, 06:29 PM   #63
pooch
pooch's Avatar
Just to add, I did not use this plastic bottle blaster when I was doing it full time.
I sold all my industrial gear when I retired.
The bottle is just an example of how to make a clog free suction/gravity fully adjustable set up.
Old 12-29-2010, 03:54 PM   #64
Flop
just about finished up with the body today besides bending the edges over the subframe on the new patches.
the passenger quarter was the last piece.
really solid but the break where it wrapped under neath was gone
made a new piece for it
couldnt figure out how to make it in one long piece so 2 pieces it was
just about done except for the edge it still needs some more smoothing where it wraps into the wheel well
and we are just about done with the body!!
Please call or email while website is down!
412 867 1659
[email protected]
https://www.facebook.com/flop.custom
Flop is offline   Reply With Quote
Old 12-29-2010, 04:37 PM   #65
Fred K-OR
Fred K-OR's Avatar
Flop, great job and looks like a brand new A body.
Fred Kroon
1929 Std Coupe
1929 Huckster
Fred K-OR is offline   Reply With Quote
Old 12-29-2010, 04:53 PM   #66
1930fordor
1930fordor's Avatar
Nice work Flop. I agree with you about the stud gun one of the best purchases I made also.
1930fordor is offline   Reply With Quote
Old 12-30-2010, 10:20 AM   #67
D-Russ
D-Russ's Avatar
Awesome work as usual Flop. How's the Pontiac coming along? I noticed a few cameo shots in this thread.
Now taking donations of money, parts or both. Inquire via PM.
D-Russ is offline   Reply With Quote
Old 01-01-2011, 01:03 PM   #68
Flop
thanks again guys. not done yet still got some little stuff and fenders to fix
dash needs some extra holes filled thats the next small project .is the passenger side of the dash supposed to have the reveal in it .you can see it where the sanding marks are.if it not its a hell of a perfect creas put in some how .
heres a pic of what everyones been asking for. what tools i use to do this stuff. once again i have no compressor use a 4500 rpms sander and a 4 1/2 inch grinder with the rubber backer cut way down so ya get less grinder marks
Druss pontiac is being neglected havent touched it in months .
412 867 1659
[email protected]
Old 01-02-2011, 01:23 PM   #69
BCCHOPIT
BCCHOPIT's Avatar
Nice work Flop...
Keep us posted
Bill
WAC that banger in the A$$ and drive it home hard
http://waccustoms.com
BCCHOPIT is offline   Reply With Quote
Old 01-02-2011, 02:50 PM   #70
CWPASADENA
CWPASADENA's Avatar
Originally Posted by Flop View Post
also tiged up some stress cracks behind the bracket that holds the support rod to the rad
Just a suggestion:
It appears you are working on an early '30. These firewalls had a bad habit about cracking around the radiator rod mounts. Ford later made a revision and added reinforcements to the back side of the firewall to help keep this from happening. You may want to think about adding something to reinforce this area. I have a early '30 Tudor that had this same problem and did not want it to re-occure so I reinforced this area when I did the repair.
Just a thought.
Chris
CWPASADENA is offline   Reply With Quote
Old 01-02-2011, 04:22 PM   #71
BRENT in 10-uh-C
Originally Posted by CWPASADENA View Post
Just a suggestion:
Just a thought.
Chris
Yes, I didn't want to be the one that said something but since Chris mentioned it, this is true. Honestly, it appears the way this has been repaired will very likely allow the crack to return since there is no welded strength around the rivets and it appears the ending-hole was not drilled to eliminate the continued spreading of the crack.
Below is a few images showing the cracks drilled, vee-ed, and filled. The reinforcing plates are added to the back side and the 4 holes are plug welded and metalfinished smooth to look more like a spot weld. The firewall rivets are heated & bucked in with a 3X gun to entirely fill the firewall hole first, then it is ground nearly flat on the backside and then waffled. The reason it is done that way is so the shank of the rivet can be red hot during installation for maximum swelling. The waffle tool is designed to be used cold, so thus it is done in two stages.
BRENT in 10-uh-C
Old 01-05-2011, 12:17 PM   #72
Flop
good tips guys
extra holes in the dash that gotta disappear
412 867 1659
[email protected]
Old 01-05-2011, 12:42 PM   #73
Fred K-OR
Fred K-OR's Avatar
Nice, what did you use for the plugs?
Fred Kroon
1929 Std Coupe
1929 Huckster
Old 01-05-2011, 01:24 PM   #74
Jason in TX
Jason in TX's Avatar
About to go through all the same exact repairs on the coupe. Wish I could just drop it off! I'll be referring to this post a whole lot!
Drive it like you know how to fix it!
DMAFC / OILERS CC-MC
Jason in TX is offline   Reply With Quote
Old 03-01-2011, 04:40 PM   #75
Flop
of course it went to the sandblaster on the snowiest day of the year
and this is what it looked like when it came back and headed back to its owner
this is just in epoxy primer no body filler
here is a short video of the car on youtube as well
https://www.youtube.com/watch?v=hXVHPi9836c
412 867 1659
[email protected]
Old 03-01-2011, 04:52 PM   #76
Jason in TX
Yup. That's real nice. How many hours do you have in repairs?
Old 03-01-2011, 05:45 PM   #77
Mike V. Florida
Mike V. Florida's Avatar
Ya get some heat from the stud gun and ya get a shrink from that mixed with the pull from the stud.
I saw at USA Weld a shrinking tip for a stud gun. I don't know if it will fit your gun.
Old 03-02-2011, 07:28 AM   #78
Flop
Jason I have between 40 and 50 hours into the car on the sheetmetal work.
Mike I have the shriknking tip it work well for a small shrink.
412 867 1659
[email protected]
Old 04-22-2011, 06:09 AM   #79
Flop
2 separate customers sets of fenders i will be posting up soon
412 867 1659
[email protected]
Old 04-22-2011, 04:12 PM   #80
1931 flamingo
1931 flamingo's Avatar
Love your work and finished products.
Paul in CT
