Old 09-22-2018, 08:46 AM   #1
jhowes
Default Evaporust/rust 911
When using evaporust or rust 911 can it be sprayed like paint on large pieces? Once a part has been subject to these products, what has to be done to lay a coat of primer on the part? Does it have to be washed in water first? Any help is appreciated. Thanks. Jack
jhowes is offline   Reply With Quote
Old 09-22-2018, 09:33 AM   #2
Chris Haynes
Chris Haynes's Avatar
Default Re: Evaporust/rust 911
I doubt spraying will work. I always immerse my parts in it and let it soak. Rinse with clear water.
1921 Runabout
1930 Tudor
Early 1930 AA
Speed costs money. How fast do you want to go?
Chris Haynes is offline   Reply With Quote
Old 09-22-2018, 01:28 PM   #3
jhowes
Chris;; soaking is the best way to use the evapo rust but how do you do a frame with this product? Jack
Old 09-22-2018, 03:50 PM   #4
Tom Wesenberg
Tom Wesenberg's Avatar
It would be cheaper to have the frame sandblasted.
Old 09-22-2018, 08:59 PM   #5
WTSHNN
WTSHNN's Avatar
I believe they recommend soaking rags or paper towels in the solution, wrap those around the metal, then wrap with plastic to prevent evaporation.
But seconded on sandblasting.
-Tim
No one wants advice - only corroboration.
-John Steinbeck
WTSHNN is offline   Reply With Quote
Old 09-22-2018, 09:11 PM   #6
30 Closed Cab PU
I am a little foggy, been awhile. Another method involves using a tarp underneath so it drains to one spot, and use with a pump to circulate the evaporust over the piece you are de-rusting. I do not know how well this works, never tried it.
30 Closed Cab PU is offline   Reply With Quote
Old 09-22-2018, 09:27 PM   #7
zzlegend
zzlegend's Avatar
Jack. I have a 57 olds 98 and the hood is punched full of louvers. A really nice hood but some what rusty on the in side. Did not want to sand blast i with all those louvers. So i taped up the outside with plastic sheet and duct tape. Flipped it over and made a large batch of 911 mixed. And made a lake in side up to the edges. After a couple of days it looked like brand new clean metal. Drained it, rinsed it with clean water and painted a good coat of epoxy primer. If you can soak the part it would be best. I am not sure spraying it on would work that good. Soaking is the best in my opinion.
zzlegend is offline   Reply With Quote
Old 09-22-2018, 10:32 PM   #8
30 Closed Cab PU
Just saw this. Evaporust Gel you can brush on.
https://www.evapo-rust.com/evapo-rust-gel/
Old 09-22-2018, 10:35 PM   #9
Mike V. Florida
Mike V. Florida's Avatar
I've seen that done.
