01-09-2014, 08:57 PM | #1 |
checking a 1952 mercury auto transmission
Help please, i have a friend with a 1952 mercury, all stock, with an origonal automatic transmission. he asked me how to check the fluid level in the transmission. all i could find on line was these instructions from a Ford service manual. could anyone please tell me if these ford specific instructions also apply to the mercury? thank you... don
Checking Oil Level—Apply parking brake, place transmission selector lever in *'N" position, run engine at Idle speed for approximately four minutes. With parking brake applied and engine running at slow Idle, move selector lever to "P" (Parking) position. When engine and transmission have reached normal operating temperature, move selector lever through all positions to assure fluid distribution throughout transmission. Return selector lever to "P" position. Raise hood, clean dirt from fluid level cap, remove Indicator. Wipe indicator clean and Insert In tube (make sure indicator Is pushed down all the way). Remove Indicator and read level. Add sufficient fluid to raise fluid level to full mark on Indicator. Replace Indicator. |
01-09-2014, 09:51 PM | #2 |
Re: checking a 1952 mercury auto transmission
I would say that those instructions will work for most cars of most any make that have dipsticks for the transmission.
01-09-2014, 10:22 PM | #3 |
