Old 06-06-2019, 05:04 PM   #1
sunshine
sunshine's Avatar
Default steering wheel removal
OK. Brain freeze .. How do I. remove the horn button and iight. Switch from my 39 Pkup. I had the wheel off to restore it 3 yrs, ago . I have forgotten. A lot lately . Thank all BOB.
sunshine is offline   Reply With Quote
Old 06-06-2019, 09:05 PM   #2
VeryTangled
VeryTangled's Avatar
Default Re: steering wheel removal
http://www.vanpeltsales.com/FH_web/F...ar_1937-39.jpg
-Jeff H
Old 06-06-2019, 10:58 PM   #3
38bill
38bill's Avatar
If your talking about the horn/light switch in the steering wheel you have to disconnect the actual switch at the bottom of the steering column (see above post for part drawing) and slide the horn/light switch rod up and out of the steering shaft. I believe that the rear window need to be removed to accomplish this without bending the horn/light switch rod.
38bill is offline   Reply With Quote
Old 06-07-2019, 01:05 AM   #4
RalphM
RalphM's Avatar
Or, take the entire column/box out.
RalphM is offline   Reply With Quote
Old 06-07-2019, 05:46 AM   #5
sunshine
sunshine's Avatar
Thanks all I am going to look a some other causes for the horn not working before I pull the rod . BOB
Old 06-07-2019, 06:54 AM   #6
JM 35 Sedan
JM 35 Sedan's Avatar
Bob, if you do decide to remove the steering wheel, be very careful not to bend the rod on the horn, light switch, rod assembly.
John
Old 06-07-2019, 01:57 PM   #7
38bill
38bill's Avatar
I took a look at mine this am. The horn rod is about 49" end to end and the dash is only 40" from the rear window glass. The steering column end is even closer to the glass. To pull the horn rod straight out through the rear window you will also have to unbolt the steering column from the dash to get a better angle so the horn rod will clear the window frame.
Old 06-07-2019, 06:37 PM   #8
sunshine
sunshine's Avatar
Thanks all I hope I never have to pull that rod .I remember now I restored the steering wheel when I had the steering box out for overhaul.WELL Verytangled came over today and we did all of the HARD things FIRST. Then HE found a bullet connected loose on the new wire harness on the firewall. I was trying to get the horn to work again. I was looking too deep .THANK You all BOB
Old 06-07-2019, 07:07 PM   #9
38bill
38bill's Avatar
Glad it worked out. Post some photos of your truck..
Old 06-07-2019, 07:29 PM   #10
VeryTangled
Sweet ride. Very peppy, shifts and stops so much better than the mechanical brake junk I work on!
We worked from the power to the horn backwards and found an open on the ground (B
+) path, that lead to the open at a bullet connector.
In true Roadkill fashion, we fixed it with a bit of electricians tape and some pushing and pulling!
This truck is super clean, has all the goodies replaced and refurbished. Sweetness!
Plus a bonus of a great grilled dogs for lunch!
-Jeff H
Old 06-07-2019, 08:24 PM   #11
sunshine
sunshine's Avatar
Thank you Jeff for posting the picture.,, you know I took it for a run this evening and that connector work loose again.I am going to find a better bullet connector. I have got to learn how to post pictures Thanks again BOB
Old 06-07-2019, 08:38 PM   #12
VeryTangled
Hi Everyone. We traced a yellow with green tracer from the horn to an extra-large gauge wire that had a bullet larger than all the others. What size bullet do we need to get this back into the reliable category? At least one step wider than std?
-Jeff H
Old 06-07-2019, 09:18 PM   #13
Clem Clement
Clem Clement's Avatar
Golly a super looking truck. I have a '39 pickup as well.
Do you have the sliding back window? This accessory solves the summer heat problems.
Coming to Sully?
