09-09-2015, 10:31 AM | #1 |
Horn amps
What amps does the Sparton pull?
Love a Lot, Trust a Few
Always Paddle Your Own Canoe |
09-09-2015, 11:15 AM | #2 |
Re: Horn amps
Mine takes 4 to 5 amps. If you are using a battery charger only rated 4 or 5 amps it might take more to get the motor spinning, but while spinning it draws 4 to 5 amps when it's adjusted correctly.
09-09-2015, 11:20 AM | #3 |
Re: Horn amps
Thanks Tom, thought it was about that, just needed confirmation, Dennis.
09-09-2015, 01:10 PM | #4 |
Re: Horn amps
Mine shows about 10 amps and mine is a Stewart Warner.
"If I asked people what they wanted they would have said faster horses." -Henry Ford "Primitive technology is not a design flaw" 1928 Ford Model A Roadster Pickup 1930 Gordon Smith Air Compressor 1941 Willy's Pickup 1960 Thunderbird-For Sale 1964 Buick Riviera 2x4 425 1965 Pontiac GTO, 455 Super Duty 2004 Dodge Ram SRT-10, V-10 Viper 1977 Charger Jet Boat,460 Ford,Jacuzzi Jet Front Engine Nostalgia Dragster,Supercharged 296 "Fullrace Flathead" Ford Engine Build up on DVD ask |
09-09-2015, 02:11 PM | #5 |
Re: Horn amps
Make sure neither field is grounded. I worked on a horn once where the motor spun OK, but one field was shorted. Just touch the ohm meter leads to one horn terminal and one to the horn mount or horn motor frame. You should get no meter movement.
I'll retest a horn later today to see what it draws. |
09-09-2015, 03:43 PM | #6 |
Re: Horn amps
09-09-2015, 11:26 PM | #7 |
Re: Horn amps
I just measured my Stewart Warner and got 6 amps. I'll try to remember to measure my Sparton tomorrow.
