11-25-2019, 02:02 PM | #1 |
Mart's Crusty Flatty Teardown Pt4. Pistons. Bust 'em out!
Having successfully got the valves and the crank out, in this episode I turn my attention to the pistons. I show them I mean business with a steel bar and a big hammer.
See how it went: https://youtu.be/0STsKGnbT44 Mart. |
11-25-2019, 04:51 PM | #2 |
Re: Mart's Crusty Flatty Teardown Pt4. Pistons. Bust 'em out!
You have to be careful doing that, a friend of mine was working on one and knocked a 3 inch hole through one of the cylinders. Then he gave me the block for parts
11-25-2019, 04:55 PM | #3 |
I’ve found that a cut down base ball bat blank is the perfect size for knocking pistons out of a block
11-25-2019, 06:16 PM | #4 |
That's why I was being very careful. I knocked a hole in the bore of a 59A motor. Luckily I was only stripping it to use as a mock up motor. It was already scrap due to extensive pan rail cracking.
I never did get those pistons out. Mart. |
11-25-2019, 10:54 PM | #5 |
I just watched the rest of the video Mart. Glad you got them all out OK !
11-26-2019, 12:05 AM | #6 |
Owner/Operator of 'Jailbar Ranch' on the side of Mt. Pickett. Current stable consists of 1946 1/2 ton pickup turned woodie wagon with FH V8, 1947 Tonner Pickup (red) mostly stock with exception of a cummins 6at turbo diesel, 1946 Tonner Pickup (green) with 226 cu in 6 cyl flathead, 1979 Toyota landcruiser wagon, completely encased in 1947 Ford Jailbar sheet metal. Ok, cornbinder rear fenders..... 'Rusty ol' floorboards, hot on their feet' (Alan Jackson) |
11-26-2019, 12:44 AM | #7 |
That’s an interesting interesting method GB. I’ve got some lead sheeting that I was going to melt down for bullets, maybe I’ll give that method a try.
11-26-2019, 12:51 AM | #8 |
I had a neighbor who was building an 86' sailboat just above me on Mt. Pickett. That's about 700' above sea level. He always collected lead from all sources for ballast. When he died in his mid 90's his son brought that roll of lead by, along with some other gems. I have always loved how it spreads the blow across the crown of the piston.
11-26-2019, 09:11 AM | #9 |
Yeah, GB, if the bores were better and the pistons not already damaged I would have tried to be a bit more sympathetic. The lead roll sounds like a good idea.
Mart. |
11-26-2019, 11:27 AM | #10 |
Now I see what I have to look forward to, didn't know about knocking off the top of the Pistons. I once had a Honda 90cc that was very stuck, I ended up buying a small punch and busted up the piston from the top, when done the rings were still stuck to the cylinder walls. It looked like someone had welded the rings to the bore.
11-26-2019, 01:31 PM | #11 |
I enjoyed the video on the pistons.... Glad I never bought a stuck engine. Lots of parts to replace. I guess even if an engine is ancient at least if it turns, you will have less problems.
11-28-2019, 07:08 PM | #12 |
Thanks for the comments, fellas. Cam and lifters video has been edited and will be posted up tomorrow (Friday).
Mart. |
11-28-2019, 07:52 PM | #13 |
geez! now i wont sleep a wink all night!
11-28-2019, 10:45 PM | #14 |
I’m popping corn as we speak!
