04-18-2018, 05:40 PM | #1 |
Hose clamp orientation
Some time ago someone went into detail here as to the correct orientation of the radiator hose clamps. I know (think) that I printed it out for later use (it's now later) but can not find it. I've searched the forum but no luck. If that could be posted again I would appreciate it.
Dave / Lincoln Nebraska |
04-18-2018, 05:59 PM | #2 |
Re: Hose clamp orientation
The JS&RG book says, 'Both radiator inlet upper hose clamps had the screw on the top side of the hose with the head towards the drivers side. On the radiator outlet hose nearest the radiator, the clamps had the screw on the drivers side with the head facing upwards. On the outlet hose at the cylinder water inlet casting, the clamps had the screw on the top of the hose with the head facing the drivers side.
Always one bad decision away from a good time. |
04-18-2018, 09:40 PM | #3 |
Is there a correct way to line up the red stripe along with the clamps?
04-18-2018, 11:05 PM | #4 |
RG&JS page 3-4
Revised 2011 "Radiator hoses were predominantly black with a red longitudinal stripe which was installed with the red stripe facing upward ........."
1931 160B & 1931 68B If you don't have time to do it right the 1st time, how do you have time to do it the 2nd time? |
04-19-2018, 07:30 AM | #5 |
Thanks , I read that area but missed the part about the red facing up . Norm
04-19-2018, 12:22 PM | #6 |
