12-27-2013, 10:58 PM | #21 |
Re: Trouble with stoplight switch
The brake pedal moves away from the switch, not towards it.
If brains were wire, some couldn't short circuit a firefly |
12-28-2013, 01:24 AM | #22 | |
I realize the pedal moves away from the switch. I was referring to the brake pedal stop.
All I'm suggesting is to check it. I think it might come close, especially if you have a low pedal for whatever reason. I would hate to see someone have no brakes sometime because of interference between the bracket and the stop.
The Master Cylinder Enjoying life at the beach in SoCal... |
12-28-2013, 08:53 PM | #23 |
Sorry, I misunderstood your concern. Now that you pointed it out, I can see what you mean.
12-30-2013, 04:16 PM | #24 |
I agree. I think you should check the pedal travel... I'm pretty sure it's going to hit either the switch or welded in bracket. I KNOW it will while bleeding your brakes.
