Old 10-14-2016, 11:18 PM   #1
700rpm
700rpm's Avatar
Default My annual antifreeze question
I ask this every year, because antifreeze products keep changing. I have always used denatured alcohol in my A's because some older types of antifreeze, if it happened to leak into the crankcase, would destroy the babbit. Can anyone recommend a current antifreeze that will not damage babbit if it gets to the crankcase?
I can still go with the alcohol, but it's getting more expensive. Maybe still cheaper than antifreeze though.
Ray Horton, Portland, OR
Old 10-14-2016, 11:33 PM   #2
Capt Quahog
Capt Quahog's Avatar
Location: Barren windswept mountain somewhere in bleak Northeastern Pennsylvania
Default Re: My annual antifreeze question
We always use PEAK brand anti-freeze. Suppose to be safe for old cars and seems to function okay in three assorted vintage automobiles as well as my 20-year Toyota Hilux truck.
For assorted reasons . . . avoid any type of PRESTONE brand
I wouldn't be so paranoid if people weren't plotting against me all the time
Capt Quahog is offline   Reply With Quote
Old 10-15-2016, 09:03 AM   #3
40 Deluxe
Ethylene glycol damages modern bearings, too. If I remember correctly, propylene glycol is OK, but do your own research first. I don't think the brand matters, ethylene glycol is ethylene glycol. It's just the additives and the advertising that is different. The additives do make it unwise to mix different types, however. With new vehicles, it's a whole different ball of wax!
Old 10-15-2016, 09:28 AM   #4
C26Pinelake
What are the assorted reasons ? Wayne.
C26Pinelake is offline   Reply With Quote
Old 10-15-2016, 09:41 AM   #5
holdover
I have all those testers mentioned, but the refractometer , so for 22 bucks I am going to try one. I have over 15 vehicles between the daily drivers, antiques and farm vehicles, would like to be able tho verify the readings.
http://www.ebay.com/itm/Car-Auto-Ant...1%26rkt%3D1%26
holdover is offline   Reply With Quote
Old 10-15-2016, 09:46 AM   #6
redmodelt
redmodelt's Avatar
Anti-freeze will not destroy babbitt. Water displacing the oil in the rods or mains will however.
Old 10-15-2016, 10:33 AM   #7
C26Pinelake
You may save a couple bucks but alcohol does no have rust inhibitor in it. Do you add rust inhibitor? You can't live in fear of what might happen. Wayne
