07-10-2011, 11:52 PM | #1 |
Deluxe Tudor
Is the lower moulding for the quarter window on the 30-31 Deluxe tudor different from the standard 30-31 tudor? I brought home a 30-31 tudor body today that seems to have a different moulding for the quarter windows. The pieces were not attached, but were atleast with the car. Looked like it was woodgrained also. Just making sure I correctly ID the pieces. The body is pretty rough, so likely will be sectioning it out when things cool back dowm some. Too hot for a day in the sun seperating the panels right now. Thanks Rod
07-11-2011, 05:48 PM | #2 |
Re: Deluxe Tudor
You should also note that all Deluxe Tudors were manufactured in '31, and have indented firewalls.
07-11-2011, 07:34 PM | #3 |
Re: Deluxe Tudor
Definately not an indented firwall. Will get pic's of the pieces on saturday and look things over abit more. Rod
07-16-2011, 08:48 PM | #4 |
Re: Deluxe Tudor
Here are the pic's. I do not get any screw holes to line up, so I am wondering if it was mounted lower as some sort of arm rest. Rod
07-16-2011, 10:36 PM | #5 |
Re: Deluxe Tudor
There should be a separate plate with rubber edge that mounts under the bottom moulding but on top of the interior body metal panel. Moulding will not fit properly without it.
07-16-2011, 10:45 PM | #6 |
Re: Deluxe Tudor
