Old 07-27-2016, 07:37 PM   #1
Bigphil
Default Modern Fuel filters for the Model A
I have a late 1931 Zenith carburetor with sidebowl on my A400 convertible sedan (indented firewall)
I need a good fuel filter - I have a metal mesh filter just
behind the firewall shut off valve, and another metal mesh filter within the sidebowl. I had to disassemble and clean the carburetor after just 250 miles due to rust particles.
How can I get modern 40 micron filter technology into this setup ? The external inline filters look like a kludge.
Is there an internal 40 micron filter that I could use ?
Something in the sidebowl would be the easiest to install.
Bigphil is offline   Reply With Quote
Old 07-27-2016, 08:06 PM   #2
SeaSlugs
SeaSlugs's Avatar
Default Re: Modern Fuel filters for the Model A
i would fix the source of the problem first....
1929 Model AA - Need long splash aprons!
SeaSlugs is offline   Reply With Quote
Old 07-27-2016, 09:09 PM   #3
J Franklin
J Franklin's Avatar
Gravity messes things up sometimes.
Old 07-27-2016, 09:43 PM   #4
Kevin in NJ
Flush the tank a few times. Be sure to shake real good before and while draining.
Make sure the screen is good on the side bowl.
Run it.
You did not say you are having problems running. The A carb is designed to handle dirt that gets past the filter and is easy to clean. If the dirt is not a super bad problem it will likely clear itself by running it a bunch.
I would expect that the amount of dirt being trapped quickly lessons as you drive it.
When dealing with the A sometimes it is best to keep things simple and work with its design.
Kevin in NJ is offline   Reply With Quote
Old 07-27-2016, 10:01 PM   #5
700rpm
700rpm's Avatar
Put a pencil filter at the top of your tank outlet.
Ray Horton, Portland, OR
Old 07-27-2016, 10:07 PM   #6
TerryH
TerryH's Avatar
Some folks have implemented a "dirty leg" type of trap, for particles to settle into before they get into the fuel line and carb. If you do a search you will find a description and photos.
TerryH is offline   Reply With Quote
Old 07-28-2016, 12:08 AM   #7
Chuck Sea/Tac
Chuck Sea/Tac's Avatar
If you have a outside gas shutoff then the pencil filter won't work.youre best off to flush the tank
Old 07-28-2016, 12:35 AM   #8
Tom Wesenberg
Tom Wesenberg's Avatar
I've done two of them with a perfect fit.
Old 07-28-2016, 02:20 AM   #9
Synchro909
Synchro909's Avatar
Maybe try dropping a magnet into the tank and positioning it near the outlet. It will catch any rust particles. I do the same in the coolant overflow tank. If possible, it's best to see to it that they can be removed at a later date for cleaning.
I'm part of the only ever generation with an analogue childhood and a digital adulthood.
Old 07-28-2016, 04:40 AM   #10
Manager
Manager's Avatar
Through all my drama I had with a rusty tank till I fixed it I never had to clean the carb out. Only got 5 or 10 miles till cleaning filters and dirty leg but never the carb.
Manager is offline   Reply With Quote
Old 07-28-2016, 04:50 AM   #11
nq50
NAPA part # 3039
nq50 is offline   Reply With Quote
Old 07-28-2016, 06:30 AM   #12
ronn
x2
I then buy the inexpensive plastic filters, like 10 at a time and change them out, right before going into the carb.
as Kevin says, in time you will be running clean whiskey!
Old 07-28-2016, 07:24 AM   #13
KGBnut
KGBnut's Avatar
I don't even put the magnets IN the tank. If you get some modern neodymium magnets, you can stick them under the dash surrounding the outlet. They catch an awful lot of it.
Keep in mind that rust itself (ferrous oxide) will not be attracted to a magnet, but rustY metal will. I find mine catches all but the tiniest bits of fine rust and the glass bowl catches the rest.
Ken
Style beats speed any day, and with a lot fewer tickets.
KGBnut is offline   Reply With Quote
Old 07-28-2016, 10:52 AM   #14
Chuck Sea/Tac
Cool Re: Modern Fuel filters for the Model A
How? Does it go in horizontally? I thought the idea was for it to stand up vertically, so the crud is stopped on say the bottom 1/3, and the rest of the screen flows clean gas. If it's horizontal, I would think you have more of a chance to plug it up. I guess I just assumed,because of the different angles it wouldn't work.
Old 07-28-2016, 11:42 AM   #15
700rpm
700rpm's Avatar
x2
I hope you are keeping those plastic filters safely away from your exhaust manifold.
Old 07-28-2016, 02:57 PM   #16
Big hammer
I have look into this for a late indented fire wall. Being horizontal it would soon plug up IMO. I instead decided to use a glass filter, a drop leg could be another choice! Someone posted pictures of a late 31 model A and it had a glass filter and this was on a assembly line!
Old 07-28-2016, 03:12 PM   #17
Chuck Sea/Tac
I have flushed my tank twice in the last 7/8 years,and added a dirty leg with an inverted pea trap 5 years ago. I've cleaned the leg a couple of times(not much in it), and haven't had any issues since. The little in line filter I used wouldn't work under heavy demand. I do drive my car all year round.
Old 07-28-2016, 07:34 PM   #18
Tom Wesenberg
Even though the filter in the valve would be almost horizontal, it still does a good job. You need to flush the tank to first get all the loose crud out, then the filter will take care of any left overs that break loose. Just flush by using a hose from the drain into a cloth covered bucket, and keep flushing until no ,more junk catches on the cloth.
Old 07-28-2016, 10:10 PM   #19
Bruce Adams
Bruce Adams's Avatar
I use this on my SW Indented tank 68C with great results. It is available at the vendors for late 1931's for around $35.
Bruce Adams is offline   Reply With Quote
Old 03-27-2022, 12:36 PM   #20
clifforddward
clifforddward's Avatar
Hello Bruce....I realize this is an old thread, but I've just purchased a 68C and am sorting through how to filter the gas....the glass filter bowl in your posting does not seem to have a fuel shutoff but seems to fit in the location of the shut off valve at the indented firewall.
Can you elaborate on how you cut off fuel?
Or can anyone else on the forum with a late 31 (indented firewall) model A provide details on filtering of fuel?
The car I just obtained has a large inline filter (see photo)...I'd like to replace with something that looks like it fits in better...at same time I swap out the Tillotson carb for a proper Zenith side bowl one.
Last edited by clifforddward; 03-27-2022 at 03:29 PM. Reason: adding comment about incorrect carburetor
clifforddward is offline   Reply With Quote
