Old 12-04-2017, 12:14 AM   #1
michael a
michael a's Avatar
Default To flathead c4 speedway adapter
speedway adapter if any of you use one of these before if so how did you like any comments are appreciated
michael a is offline   Reply With Quote
Old 12-04-2017, 07:16 AM   #2
FHFD
FHFD's Avatar
Default Re: To flathead c4 speedway adapter
Not sure about Speedways..but since you're considering a C4 behind a flathead, I'd recommend Flat-O-Matic out of Oregon.
I used Genes (Flat-O-Matic) quite pleased with it, been in my '40 now for several years.
"Get your facts first..then you can distort them as you please"
FHFD is offline   Reply With Quote
Old 12-04-2017, 09:12 AM   #3
Krylon32
I'm installing a Speedway C4 kit behind a 8BA this morning. Only draw back is a little grinding on the block for the starter to clear. Everything bolted together good. I'm putting this in a customers Model A chassis I built. Looks good together. I've done a Flat O Matic kit which also worked good.
Krylon32 is offline   Reply With Quote
Old 12-04-2017, 09:20 AM   #4
skidmarks
skidmarks's Avatar
I have the flat o matic kit and its pretty nice stuff, but havent installed it yet
Speedways stuff is knockoffs of other peoples stuff. Most of its OK but some of its pretty bad
skidmarks is offline   Reply With Quote
Old 12-04-2017, 09:35 AM   #5
Ol' Ron
Ol' Ron's Avatar
I like the speedway adapter for installing the AoD Trans. The overdrive is very useful.
Old 12-04-2017, 09:55 AM   #6
TJ
TJ's Avatar
I and two others have used the Flat-O-Matic kit. It uses a smaller bell housing to clear the earlier firewalls. As I recall the Speedway kit uses the stock C-4 bell housing. that works good in the '41 and up cars , but may cause clearance issues in '40 and older cars.
Old 12-04-2017, 11:05 AM   #7
George/Maine
George/Maine's Avatar
Ford has 2 bell housing large and small 6 bolt. I used the small in my 39 ford and if you have trouble finding a c4 you can use one from 6 cylinder like a 80 Granada.
Best thing you can do for a good trans.
George/Maine is offline   Reply With Quote
Old 12-04-2017, 11:14 AM   #8
Ardun
Ardun's Avatar
I used Speedway’s adaptor for an AOD on an 8ba. Easy install with a little grinding for the starter. No issues or anything bad whatsoever.
Ardun is offline   Reply With Quote
Old 12-04-2017, 12:10 PM   #9
Krylon32
After doing this install and having the block ground for the stock Ford style starter, I'm thinking why don't they use a Powermaster gear reduction starter which can be clocked for clearance and is smaller?
Old 12-04-2017, 04:04 PM   #10
George/Maine
You can use power master with flatomatic they do sell other starters like pm 302 and flathead are different I think
Old 12-04-2017, 04:06 PM   #11
TJ
TJ's Avatar
I used the Powermaster mini starter on mine and it worked perfect. Also no more Bendix spring.
Old 12-04-2017, 05:49 PM   #12
Ardun
Ardun's Avatar
I am very happy with Ford Truck 12 volt starter. No big deal on grinding. Some don’t require grinding.
