Old 04-06-2017, 02:46 PM   #1
KenCoupe
KenCoupe's Avatar
Default Door Post Wood
I have a 1931 Coupe. I ordered the wood piece in the picture below from Fordwood. I am not sure how to attach this to the channel in the door post. Do I glue/epoxy it, is it somehow screwed in, or what? The door post area did not have this piece, so I don't have an example.
Thanks for any help you can give me.
Ken
KenCoupe is offline   Reply With Quote
Old 04-06-2017, 03:12 PM   #2
Mitch//pa
Default Re: Door Post Wood
This is from a Tudor...
Held by 2 screws.
Old 04-06-2017, 07:04 PM   #3
Big hammer
And a few nails for the body skin, i think, in the door opening. It's been a while, and maybe a couple of nails install by ford behind the body skin that you can't get to easily, again it's been awhile
Old 04-06-2017, 11:26 PM   #4
KenCoupe
KenCoupe's Avatar
Thanks both of you for the help and the photo. Both very helpful.
Ken
Old 04-07-2017, 12:01 AM   #5
Drive Shaft Dave
Ken, in my 1930 coupe it was held in by two screws.
Drive Shaft Dave is offline   Reply With Quote
Old 04-07-2017, 12:57 AM   #6
KenCoupe
KenCoupe's Avatar
Thanks Dave. I am going to look at it again tomorrow morning.
Ken
Old 04-07-2017, 04:23 PM   #7
Mr T Body
Ken
A Fordwood piece. Expect to need a wood chisel and beltsander to get the depth correct. Just went through this last week.
Patience......
Mr T Body is offline   Reply With Quote
Old 04-08-2017, 06:37 AM   #8
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
You've seen that REALLY strong adhesive used to glue in windshields, I've seen it used in HIDDEN places, to help secure wood pieces such as this one.
Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 06-26-2019, 05:23 AM   #9
dmaxweb
dmaxweb's Avatar
Patience......
I'm working on replacing these in my 30 coupe. I bought new ones and they do not have the lower slot. It looks like that is for the long bolt that goes though the door post to the door frame backed by a square nut. Is that correct? Also, the upper screw hole is not centered. I'm assuming that's going to have to be filled and redrilled.
dmaxweb is offline   Reply With Quote
