08-13-2018, 07:19 PM | #1 |
Camshaft Plunger !!!!
I'm trying to help a friend "reassemble" his Dad's '31 Murray sedan. The motor has been out of the car for years. He has reinstalled the engine and took the time to put a new timing gear in it. Yesterday, on the first attempt (in years) to start the engine... it fired right-off but with a very loud noise (according to his telephone description). I'm suspecting he did not grease the Camshaft Plunger ( Les Andrews failed to mention this !!) and my question to you experts ... can the timing cover be removed without removing the radiator? ... I think there's about 10 bolts if you include those from the oil pan. AND what kind of grease do you recommend to "lather" the plunger with ???
Many thanks.. I love this site !!!! IndyA |
08-13-2018, 07:29 PM | #2 |
Re: Camshaft Plunger !!!!
Yes on removal, but you will have to support the engine to remove front motor mount bolts, and Generator removal, have to put on new gasket on cover. can be done tho! some good mystic red grease.
www.whidbeymodelaclub.com |
08-13-2018, 10:29 PM | #3 |
Try some heat and cool cycles first. I had the same thing with a customer's car that someone else overhauled the engine and didn't lube the plunger. It made a squeal that scared me until I figured out what it was. After several heat and cool cycles the noise finally quit.
08-13-2018, 10:45 PM | #4 |
Doesn't the oil pump throw oil over the cam gear? I thought that is where the valve chamber empties.
08-13-2018, 11:12 PM | #5 |
08-15-2018, 05:06 AM | #6 |
http://www.model-a-ford-4bangers.com/ |
08-14-2018, 09:31 AM | #7 |
I would try removing the side cover and squirt some oil onto the plunger.
08-14-2018, 09:31 AM | #8 |
I have had the experience of a new plunger making a high pitched squeal. There is no need to take the covers off:
1. The squeal will go away as motor oil gets into the plunger; 2. Spray motor oil through the timing pin hole in lieu of removing the covers.
Bob Bidonde Last edited by Bob Bidonde; 08-15-2018 at 07:42 AM. |
08-15-2018, 09:18 AM | #9 | |
08-15-2018, 10:55 AM | #10 |
Over fill it by 2 quarts, oil will splash everywhere---- and some will leak out, then make a fast stop
