Old 09-20-2019, 11:32 PM   #1
zoegrant
zoegrant's Avatar
Default To seal ornot
just finished installing my rear main seal and am getting ready to install the oil pan. I have used HI-TACK on the gasket to pan...the question is should I use HI-TACK on the pan gasket to the block ????
What do you think ?
zoegrant is offline   Reply With Quote
Old 09-21-2019, 09:38 AM   #2
54vicky
54vicky's Avatar
Default Re: To seal ornot
if you put it on block you will have an almost impossible time removing pan at a later time.just do not over tighten bolts when installing
54vicky is offline   Reply With Quote
Old 09-21-2019, 10:17 AM   #3
Ole Don
Ole Don's Avatar
I like to glue the gasket to the pan, then spray with WD40 so it will release. Its easy to carry a pan or a rocker cover to the bench to clean.
Ole Don is offline   Reply With Quote
Old 09-21-2019, 09:55 PM   #4
slumlord44
I glue to the pan and put a light coat of grease on the gasket side. As said if you glue both sides have fun ever pullng the pan off.
slumlord44 is offline   Reply With Quote
Old 09-21-2019, 10:01 PM   #5
Daves55Sedan
Daves55Sedan's Avatar
I would NOT glue the gasket to the engine block, only glue the gasket to pan. Don't want to take the chance of bending the mounting flange of the pan with a screwdriver when trying to remove the pan next time!
Daves55Sedan is offline   Reply With Quote
Old 09-23-2019, 09:47 PM   #6
zoegrant
zoegrant's Avatar
Thanks to all...
Old 09-25-2019, 12:14 PM   #7
richard crow
why glue it on either side it,s a thick gasket & IT IS ONLY SUBJECT TO SPLASH NOT PRESSURE a little grease to hold it in place is all that is needed
richard crow is offline   Reply With Quote
Old 09-25-2019, 02:04 PM   #8
scicala
scicala's Avatar
Because, if you glue the gasket to the pan it can't shift out of place if you bump something. With grease the gasket can shift if you bump something.
If your talking about with the engine out of the car, that's a different story.
Sal
Old 09-25-2019, 07:49 PM   #9
paul2748
paul2748's Avatar
To prevent the gasket from shifting during install, tie some thin string in about four holes to hold it in place.
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 09-25-2019, 10:52 PM   #10
zoegrant
zoegrant's Avatar
I ended up using a light coating of Hi-tack on the seal side to block to hold it in place while I installed the bolts which I coated liberally with Hi-tack. Generally with Hi-tack one would use the sealer on the gasket and the pan, let it set for one minute and put them together but coating just one side gave me more working time to get the pan in place. I gently tightened down the bolts figuring I could always go back and tighten them again it there were drips from the pan..no drips from the pan.
I hand tightened them flush and then did about a 1/4" turn with the socket wrench.
