07-18-2019, 04:44 PM | #1 |
Tuning For Speed-Major Tuning (Blueprinting)
In our little Hot Rod book it goes like this:
Minor tuning-carburetor and ignition Major Tuning-checking engine clearances. Will list their list of things to check. Here are some things we do on engines. Run a bottom tap down head bolt holes and main cap bolt holes. Clean oil galleries with gun brushes and diesel. Clean bores with paper towels and triclor. Have fun!
'Has racing made you a millionare?' 'Yes it has.Before I was a multi-millionaire.'-Quote |
07-18-2019, 08:48 PM | #2 |
Re: Tuning For Speed-Major Tuning (Blueprinting)
Here is list.Goal is to bring within factory clearances.
Deck height. Rods-Length, diameter and roundness of big ends. Crankshaft Variations in main bearing journals and crankpin Roundness and alignment(journals, crankpins) Stroke length and crankpin spacing All this crankshaft stuff can be done taking it to crankshaft shop and checking it when you get it back.They fix problems by grinding off center. Compression height Piston pin fit Balance engine when all of above is done. Have fun!
07-18-2019, 10:53 PM | #3 |
The connecting rods as well as pistons are usually weight matched with each other.
07-18-2019, 11:36 PM | #4 |
'connecting rods as well as pistons are usually weight matched with each other'
True. I read a little and typed.Just hit the high points from article. it's actually Hot Rodding the Buick by Hot Rod magazine. Most V8's are the same. If I remember right they grind of the flat spot on big end of con rod to match the weights of all rods to lightest one. THEN they balance rotating assembly. Getting ready to assemble one engine.Sending block to machine shop.
07-19-2019, 10:28 AM | #5 |
If you have a suitable scale and a large-ish collection of rods you can weight match potential sets of eight before you begin grinding. (using the lightest originals first when possible)
07-19-2019, 10:53 AM | #6 |
Would have for our Ford OHV V8(term from 50's Hot Rod books, Y block now) but our 292 met a horrible fate. Looking for a bigger crying towel like the big ones in the old movies.Put it around you and it is up under your arms.We want one of those for a crying towel! 'Hall of Shame'.That fits that situation big time. That is not happening with these new engines.I'll spit blood to hang on to them! Anyhow.The deal with major tuning/blueprinting like going over the ignition is to actually do all the stuff and not just blow it off. Like we may not have the machining done(unless we find a big old problem) but we are going to put the time in and do the measuring. Have most of the tools.Inside gauge, mic's and dial indicator w/stand.
07-19-2019, 11:24 AM | #7 | |
Last edited by badassfrombadaxe; 07-19-2019 at 02:08 PM. Reason: remain in the Ford barn |
07-19-2019, 02:08 PM | #8 |
In the slots in the penny loafers I had sometimes Lincoln pennies and sometimes Mercury dimes.
07-19-2019, 04:44 PM | #9 |
Thank you Badaxe Resident
Maybe this will do something for you.Ring your bell so to speak. Have you ever seen an Overhead Camshaft conversion engine up close? That is one thing I think we could get fired up over. Or at least something in that direction. '68 Hot Rod magazine has Ford factory experimental ones. Then there are two Chevy Double Overhead Camshaft conversion in '70's and 80's Hot Rod magazine. Have a sneaky idea about using two factory camshafts.One on each head. Have them work right on the valve stem .That is as far as we have thought about it. With the pushrods out of the way you can design a better combustion chamber.Locate valves across from each other.IN and OUT.Straight across chamber. EDIT Plus it saves weight on valve train.Less parts.No lifters or pushrods. Engine will rev freely.Hit higher RPM's more easily. Badaxe let me know.
07-20-2019, 12:50 AM | #10 | |
If you run the cam directly on the valve stem you will need much taller lobes on the cam than a stock OHV cam has. Rocker arms do more than just "teeter-totter". They add a lot to total valve lift. Let's say your cam has a lobe lift of .300" and the rocker arm has a ratio of 1.5 to 1. This makes valve lift .450". So your OHC conversion needs a cam with .450" lift instead of .300" lift to get the same valve lift. More engineering to do! Last edited by 40 Deluxe; 07-20-2019 at 11:29 PM. |
07-20-2019, 09:04 AM | #11 |
'need much taller lobes on the cam than a stock OHV cam'
Thought there might be a problem with using two stock camshafts. Attempted to be budgetary about it. It would have been better to do this in the 80's when we were all hooked up with machine shops and even rented space from a 'pattern shop'. That is the beginning of casting parts.Making a pattern to go to casting shop. Just did not think of anything like this then.Could have had all the cast parts we wanted for medium money. Okay.So Overhead camshafts are out. Supercharging we will give it a whirl.Paxton or GMC/Roots type.Put ad in Wanted section here.If nothing happens then that is out. Twin engines has a little appeal.Will keep thatt in the maybe file. That leaves us with running the race gas down the street in basically stock engines. Fabricated intakes.Originals prices don't work for us.Headers.Drag type. We'll live I suppose.Could be worse.
'Has racing made you a millionare?' 'Yes it has.Before I was a multi-millionaire.'-Quote Last edited by all american boy; 07-20-2019 at 09:56 AM. |
07-20-2019, 05:19 PM | #12 |
07-20-2019, 06:10 PM | #13 |
Looks like you meant to put that in the other thread because it is about 292.
As far as redesigned heads the last 351 redesign the 351 M is a nice engine. Blew the deal for a pickup with one in it. The 351 is a good way to go because of all the extra cubic inches. Think there might have been a 400 too.That would be a good one. 429/460 are good because they are later designs. Boss 429 is very interesting.Another should have picked one up in 80's for cheap deal. Oh well! Didn't know about them then.
07-20-2019, 06:14 PM | #14 | |
07-25-2019, 11:40 AM | #15 |
'Yes, there was a 400. Same as the 351M except 1/2" longer stroke'
That would be our choice in a Ford small block. We will always take the extra cubes. 80's racing method.More cubes instead of 'High RPM Parts Scatterer'. Saw a 100% original 289 down to stickers on air cleaner in a rusty out of state 4 door locally here. It was pretty cool looking.Had some saying on the sticker. Mid 60's car.
07-25-2019, 01:41 PM | #16 |
I wouldn't call the 351M or 400M a small block. They are based on the Cleveland 351 block which is a bigger and heavier design than a 302 or 351W.
The 400M was also one of the biggest slugs and fuel inefficient engines Ford made. Sal |
07-25-2019, 02:40 PM | #17 |
Location: Howell, Michigan, USA, The Peoples Slightly Overspent Demodependancy of Michigan
Sal, if you won't be so closed minded about this stuff, you might learn something.
07-25-2019, 04:32 PM | #18 |
'if you won't be so closed minded about this stuff, you might learn something'
Well.Bless my soul.That is a rare statement these days! Sal might have a leg to stand on actually. The M engines I THINK might have bigger journals for the mains and rods. So.It would be sort of a separate engine. But it is linked to the Windsor or Cleveland family of small blocks. As far as the 400 being a gas guzzler.I would say a non smog build with a two barrel and torgue small passage intake manifold would be the ultimate test of how much of a gas sipper it could be. But I think the heads are good breathers so it is better just to forget that stuff and GO RACING with it!
07-25-2019, 05:43 PM | #19 | |
All I was doing was correcting info about a 351 and 400M being small blocks. Am I supposed to agree with that ? I thought the Barn was for people with questions and people commenting to help. Sal |
07-25-2019, 05:57 PM | #20 |
'Am I supposed to agree with that ?'
Yes you are because 351M and 400M are part of the Cleveland small block family. Yes.The 400 is a larger displacement than many many big blocks including the FE 390.But that is neither here nor there. Read this article if you care to learn something. https://en.wikipedia.org/wiki/Ford_3...e#400_and_351M 'You can lead a horse to water but you can't make it drink.'
