Old 01-09-2013, 09:00 AM   #1
brokenspoke
Default 3/4 ton rear end --1 ton rear end
Is there any difference between a 3/4 and 1 ton rear ends?
brokenspoke is offline   Reply With Quote
Old 01-09-2013, 09:24 AM   #2
Barry-ct
Barry-ct's Avatar
Default Re: 3/4 ton rear end --1 ton rear end
You need to elaborate about what year vehicle you want information for. THen someone can help you .
Barry
50 F-1
Barry-ct is offline   Reply With Quote
Old 01-09-2013, 11:25 AM   #3
Newc
Newc's Avatar
Hi all; Sounds like F-2/F-3 question. In '48 both had 8 lug hubs 16" /17" wheels, Rear diff was the same floater type. 39-47 used the floater also, but with two different wheel patterns. The rear diff looks the same 39 thru 48, with different drums? More input Barners?, the old circle trackers want the rear diffs. Newc
Old 01-09-2013, 12:20 PM   #4
brokenspoke
I assumed that since this was early v8 I didnt need to post....so mid 30's to early 50
Old 01-09-2013, 12:23 PM   #5
brokenspoke
This helps....I am looking for one to purchase and its a one ton....its a floater rear end....I was wanting a 3/4 ton....so its probally the same....
Old 01-09-2013, 01:09 PM   #6
1952henry
1952henry's Avatar
In 48-52, both F2 and F3s (heavy duty) were 3/4 tons. The F4 was actually the one ton. Its axle is much larger.
I dig coal, which provides motivation for EVs.
1952henry is offline   Reply With Quote
Old 01-09-2013, 06:50 PM   #7
expavr
expavr's Avatar
The early (39-41) one ton rear ends came with 17" backing plates, drums and 5 lug split rim wheels. The early 3/4 tons used a 16" brake system on the rear end. If you're thinking about using a 16" system you will have to find all the hardware (backing plates, drums and rims) to do the conversion. The later 48-52 one ton rears might have come with 16" brakes. Its easy enough to check the drums that are on the rear you're thinking about buying. Also the early one tons came with 4.86 gears not the best for highway cruising. There are after market 4.11's available for the one ton diff. from Chuck's Trucks. I put a set in my 40 Tonner which dropped the engine RPM significantly. From what I remember the dimensions of the housings were the same.
expavr is offline   Reply With Quote
