Old 12-29-2019, 10:42 PM   #1
Clem Clement
Clem Clement's Avatar
Default Oil change process
being dormant with my cardio rehab program, I forgets stuff.
After draining out my oil, can I add a quart into the filler hole and will that washout the old oil in the dip tray?
Thanks
Clem Clement is offline   Reply With Quote
Old 12-29-2019, 11:01 PM   #2
MAG
MAG's Avatar
Default Re: Oil change process
No. It will go directly into the oil pan. The drip try can only be filled or added to by the oil circulating system driven by the operation of the engine.
I noticed the harder I work the luckier I get!
MAG is offline   Reply With Quote
Old 12-30-2019, 12:19 AM   #3
Jim/GA
Jim/GA's Avatar
Thanks
Don't worry about it. Just change the oil and drive. Have fun!
Jim Cannon
Former MAFCA Technical Director
"Have a Model A day!"
Jim/GA is offline   Reply With Quote
Old 12-30-2019, 06:12 AM   #4
Patrick L.
Patrick L.'s Avatar
You can remove the distributor and add a qt or 2, but, like Jim said, I don't think you need to worry about it.
Old 12-30-2019, 09:03 AM   #5
old31
Just change the oil as normal, then drive it like you stole it!
Old 12-30-2019, 09:55 AM   #6
Clem Clement
thanks all.
Happy New Year
Old 12-30-2019, 10:09 AM   #7
Bob Bidonde
Bob Bidonde's Avatar
Go play with your trains instead. It's too freaking nasty outside to be driving an "A"!
Here you are driving in miniature!
File Type: jpg 2016 Bobs O-Gauge Model Railroad 194kb.jpg (82.7 KB, 104 views)
Bob Bidonde
Old 12-30-2019, 03:49 PM   #8
Clem Clement
The cardio rehab is progressing very well. I'm about 1.2 way done.
I got 2 duty times as the National Christmas tree. I love doing the trains there.
In early Feb WGHT comes to town. I will be running standard gauge trains there.
It sure looks like the oil entering hru te vent pipe lands in the dip tray.
CLEM
Old 12-30-2019, 05:24 PM   #9
The Master Cylinder
The Master Cylinder's Avatar
It sure looks like the oil entering thru the vent pipe lands in the dip tray.
CLEM
I sure does, doesn't it?
The Master Cylinder
Enjoying life at the beach in SoCal...
The Master Cylinder is offline   Reply With Quote
Old 12-30-2019, 05:31 PM   #10
J Franklin
J Franklin's Avatar
The reason behind dumping a quart down the distributor hole on a new rebuild is to get oil into the valve chamber and bearings. After that just change oil as usual.
Old 12-31-2019, 10:15 AM   #11
Bob Bidonde
Motor oil gets to the dip tray in the crankcase 3 ways:
1. Oil poured down the breather pipe;
2. Overflow out of valve chamber into the timing gear area;
3. Oil exiting the oil return pipe.
Bob Bidonde
Old 12-31-2019, 10:52 AM   #12
Clem Clement
Thanks all.
Happy New Year
Old 12-31-2019, 11:29 AM   #13
The Master Cylinder
And a small amount from the other main bearings?
The Master Cylinder
