Old 07-09-2016, 08:22 AM   #1
kwisor
kwisor's Avatar
Default update on dropping the rear end from car
hello
I was taking thing loose to pull the transmission from the car when I took the front wishbone loose from the bell housing the broke pin fell out ilooked at it and took some needle nose plyers put the new pin in the fork took a punch had to use the flat side that you hit with hammer on the pin and was able to put the new pin in now put it back together and drive
thanks for all the help
kevin
1930 tudor
kwisor is offline   Reply With Quote
Old 07-09-2016, 10:28 AM   #2
Joe K
Joe K's Avatar
Default Re: update on dropping the rear end from car
Its nice when an anticipated repair goes BETTER than planned.
But - I didn't mention this earlier as I didn't want to discourage. I'm surprised you didn't find at least TWO other issues requiring additional repair along the way. Isn't that how it usually goes?
So now go get your ice cream knowing that spring center bolt is fine - at least for now.
ONe of my faves - "The Secret of the Machines" by Rudyard Kipling.
But remember, please, the Law by which we live,
We are not built to comprehend a lie,
We can neither love nor pity nor forgive.
If you make a slip in handling us you die!
We are greater than the Peoples or the Kings—
Be humble, as you crawl beneath our rods!-
Our touch can alter all created things,
We are everything on earth—except The Gods!
And another: the engineer's corollary -
"There is nothing that cannot be repaired."
https://www.quora.com/Whats-the-diff...nt-be-repaired
"[There is] nothing that can't be repaired" -- a universal statement meaning that everything is repairable. Unprovable, and probably false, but maybe intended as a kind of life philosophy or a boast from someone who believes they have the skills to fix anything.
Joe K
Shudda kept the horse.
Joe K is offline   Reply With Quote
