Old 02-27-2019, 09:17 AM   #1
Topher5150
Default 47 Ford bumper frame mounts
I'm thinking of a design for a bracket for some large caster wheels to move a 47 Ford onto a trailer with no rear axle. I was thinking about mounting them to where the rear bumper mounts, and I can't remember are the bumper mounts on the frame threaded, and if so what size are they?
Topher5150 is offline   Reply With Quote
Old 02-27-2019, 11:30 AM   #2
RalphM
RalphM's Avatar
Default Re: 47 Ford bumper frame mounts
There are two bolts on each side of the frame that holds the bumper braces on. The bolts are half inch national fine and are spaced three and three-quarter inches apart on centers
They are also on a slight angle upwards towards the front of the car
There are nuts on the backside, they are not caged nuts like the front bumper bolts are.
RalphM is offline   Reply With Quote
Old 02-27-2019, 11:33 AM   #3
Topher5150
excellent thank you...do you know what pitch that is???
Old 02-27-2019, 11:58 AM   #4
RalphM
RalphM's Avatar
20 tpi
But you could use any half inch bolt or nut because it’s not attached to the frame, or doesn’t appear to be.
Old 02-28-2019, 11:33 AM   #5
Topher5150
some reason i thought there was a nut attached to the frame
Old 03-01-2019, 11:30 AM   #6
RalphM
RalphM's Avatar
Pinch nuts on back side.
File Type: jpg 25AE2CDB-A0D7-4B63-9968-B84890E4CFCB.jpg (25.1 KB, 8 views)
File Type: jpg FCED09EA-F45E-4F93-8B54-3225E58EDCB5.jpg (28.7 KB, 8 views)
