Old 10-20-2019, 05:41 AM   #1
Grantique
Default 1931 Wide bed problem
I purchased a wide bed from Mack's in Mobley Mo. I received the wood rails with the bed that go between the bed and the frame. My problem is the thickness of the wood is 1/4 inch thicker than the lip on the bottom of the lower sides that measures 1 3/4 inches. The bed is 46 inches wide. I temporarily mounted the wood rails on the frame and they measure 46 inches outside to outside. Now when I position the wood rails on the bottom of the bed I lose 3/4 inch on both sides because the rails do not slide into the opening on the lower bed sides. I called Mack's and Joy told me the wood was to spec. She also stated they never have installed one of their beds on a Model A???????? Does anyone have photographs of the installation of the wood rails installed? Did I received the wrong thickness of wood rails? Should I create a groove in the rails to slide into the sides of the bed? Any help on this will be much appreciated. Thank you.
Larry
Grantique is offline   Reply With Quote
Old 10-20-2019, 09:12 AM   #2
1931 flamingo
1931 flamingo's Avatar
Default Re: 1931 Wide bed problem
Got a pic?? And your location, may be someone close bye who could take a look??
What are you using for rear fenders??
Paul in CT
Old 10-20-2019, 11:04 AM   #3
Bob C
Somebody posted these before.
Bob
Old 10-20-2019, 12:28 PM   #4
ford31
ford31's Avatar
i bought my bed from macks it was put together this maybe 10 years ago look perfect
ford31 is offline   Reply With Quote
