Old 03-01-2019, 09:20 AM   #1
wbs
Default 1930 roadster rumble seat
hello car received in parts
1. the curve outer panel under lid has all 6 bolts broken off in nuts--i may want to re tap them depending on answer in number 2--what is size of screws and threads per inch?
2. do i even need a curved inner panel that mounts to number 1? what is curved inner panel purpose?
thanks
wbs is offline   Reply With Quote
Old 03-01-2019, 09:47 AM   #2
37 Coupe
37 Coupe's Avatar
Default Re: 1930 roadster rumble seat
I think they are # 10-32 but will check to make sure.I pm you to ask for a picture of exactly what you are talking about.I think the curved panel is or was somewhat important as a good drainage design. Some over the years change to flat to help clear deck lid easier.
"Never complain,never explain"... Henry Ford II
37 Coupe is offline   Reply With Quote
Old 03-01-2019, 05:08 PM   #3
wbs
thank you for your reply--i have attached a copy of the curved inner rumble panel--hope fully it will transmit
Old 03-01-2019, 05:13 PM   #4
wbs
retry sending picture of curved inner panel
Old 03-01-2019, 06:04 PM   #5
MAG
MAG's Avatar
#10-32 is correct. 5/8" oval head.
I noticed the harder I work the luckier I get!
MAG is offline   Reply With Quote
Old 03-02-2019, 06:55 AM   #6
wbs
thank you mag and 37 coupe
Old 03-03-2019, 07:57 PM   #7
37 Coupe
37 Coupe's Avatar
Well now I have a question.The curved pan is attached on the sides with three fasteners per side but mine are all missing.Anyone know what type screw and nut? Were the nuts like a cinch nut and what thread? Thank You.
