Old 08-01-2013, 07:27 PM   #1
Shadetree
Shadetree's Avatar
Default My `51 F1 Rides Like A Road Wagon...
I am not sure what a Road Wagon is but I have always heard this expression. I picture a horse drawn wagon with no springs. I know, I know when this truck was made it was for haulin' not cruisin' the boulevard on Saturday night. But surely it didn't ride this rough when new. Would removing some of the spring leaves help? What have you F1 owners done to soften the ride?
Son, you will never blow an engine up in high gear.
Shadetree is offline   Reply With Quote
Old 08-01-2013, 10:30 PM   #2
RMR&C
RMR&C's Avatar
Default Re: My `51 F1 Rides Like A Road Wagon...
Yes, you can remove some leaves. I think I took out 4-5 from each spring. It won't help the cornering, but will ride much better.
RMR&C is offline   Reply With Quote
Old 08-01-2013, 11:53 PM   #3
Ross F-1
Ross F-1's Avatar
Does the truck have original springs? You can identify them by the grooves in the springs and dog-eared ends. The dog-ears tend to dig in to the leaf above, to the point they stop sliding, effectively locking them up. Grinding the ends smooth will help, if they are dug up too much already.
BTW, 500 lbs in the bed makes them ride like a dream!
'52 F-1, EAB flathead
Ross F-1 is offline   Reply With Quote
Old 08-02-2013, 03:15 AM   #4
Vic Piano
Vic Piano's Avatar
Bud, are you running radial tires... if not, that will smooth out the ride. I run radial tires on our '51 F-1 and I drive it on the highway and around town and it is fine. I have the original springs, etc. Vic
Imagination is more important than knowledge.
Vic Piano is offline   Reply With Quote
Old 08-02-2013, 05:45 AM   #5
GreenMonster48
GreenMonster48's Avatar
I too just switched to radials. Night and day difference!
GreenMonster48 is offline   Reply With Quote
Old 08-02-2013, 06:21 AM   #6
HOTRODSURFER
HOTRODSURFER's Avatar
X2.. radials will make a huge differance in the ride
HOILER AUTO REPAIR est 1918
https://www.facebook.com/pages/HOILER...16725868370435
HOTRODSURFER is offline   Reply With Quote
Old 08-02-2013, 06:31 AM   #7
Pete Fl/Wi
Pete Fl/Wi's Avatar
Radials run a little low on tire pressure. Posies springs made a big difference in ride.
Pete Fl/Wi is offline   Reply With Quote
Old 08-02-2013, 07:22 AM   #8
4tl8ford
4tl8ford's Avatar
Just a reminder - It's a truck - a truck that was designed to work unlike todays trucks - I can remember riding in mid/late 50's trucks when new and they bounced you all over the seats, vibrated and shook - didn't matter if it was loaded or not
Anyone saying that they rode like a dream was having nightmares
Dick C
Erie, PA
1996 Exploder
1952 Ford F2 (Driver)
1948 Ford F1 Panel (Frame off resto-rod)
1946 Ford Coupe (Basket case)
4tl8ford is offline   Reply With Quote
Old 08-02-2013, 07:49 AM   #9
alan
remember the short springs hold the weight, the long springs are for the ride, with that in mind take out every other short spring and add some teflon sheets between the left over springs, made my 3/4 ton ride a lot better, then I added radial tires and made the wife happier!!
alan is offline   Reply With Quote
Old 08-02-2013, 08:45 AM   #10
Firepower flyer
Firepower flyer's Avatar
When I rebushed my front and rear springs I had to repalce the two rear springs with new ones.I didn't like how high it sat or the ride. I pulled four leaves out of each rear and it sits and rides good.
Joe
Firepower flyer is offline   Reply With Quote
Old 08-02-2013, 10:57 AM   #11
El Rat
If the shocks have been replaced with gas filled ones that could be the problem. They just didn't work on my buddy's 52 Chevy pup. The ride was so rigid and unforgiving that it was like having a 2 X 4 between the frame and axle...
I used to be indecisive but I'm not so sure any more...
El Rat is offline   Reply With Quote
Old 08-02-2013, 09:01 PM   #12
Shadetree
Shadetree's Avatar
Thanks everyone! I saved your comments. This will make a good winter project.
It does have new shocks placed by the previous owner, not sure if they are gas filled.
