11-20-2021, 02:49 PM | #21 |
Re: Perch pin removal help
Theres some good ones, I like the turning one to
11-21-2021, 08:33 PM | #22 | |
It's probably a two guy effort. You are right it's awkward and almost impossible by yourself. Not about you cas. If you have a 10 ton press or a 1,000 ton press the results will be the same. The pin can only take so much before damage/distortion. Put some pressure on it and watch what is happening. . Last edited by Tinker; 11-21-2021 at 08:57 PM. |
11-22-2021, 06:30 PM | #23 |
UPDATE: truck and diesel shop was able to remove the perch bolts. Guy who did the work wasn’t there when I picked it up to find out how it got if freed but axle does have some “battle scars”; one end of axle is has slightly out of round perch boss and bent a little up and in. Good thing a have someone lined up to lower it and will bring it back to life. Thanks all. D
11-23-2021, 12:43 PM | #24 |
They bend easier than a person might think but it takes experience or trial and error to find out how much past the neutral line you have to bend to get it to stay at the neutral line when the pressure is released. A worn or stretched king pin bore can be milled out and bushed back to specs with a steel bushing that is welded or pinned. A person needs the alignment rods to check them at all four bores for alignment and proper angles. I believe it is 7 degree angles apex toward top for all of them with all rods aligned with the beam center line.
11-23-2021, 12:49 PM | #25 |
Be cautious about heating the axle, such as red hot. It can affect the temper of the axle. I know from experience how difficult it is to get the perch holders out. Beating on them will likely swedge them, making them tighter. We get them occasionally at our machine shop, and prefer to having them before others have tried the job.
11-24-2021, 12:41 AM | #26 | |
So the 200$ question. Did they save the pins? Getting them out is one thing. Saving the pins is another. Dropping the axle link. Of course plenty of options. Always different ways to do things. https://droppedaxles.com/ |
11-24-2021, 08:55 AM | #27 |
Yes, they gave me back the pins but I don’t think one is reusable. Not a big deal because I am going with newer, longer ones so I can bolt on lower shock mounts.
11-30-2021, 10:12 AM | #28 | ||
and while the "professionals" maybe good at their normal job; many times old car stuff is out of their wheelhouse and "battle scars" are the result. Quote:
On the other hand I did get a few more later model perch bolts out the other day. |
11-30-2021, 11:01 PM | #29 |
Couple of those look suspiciously like also 38-39 trucks. Trucks always got all the left over car run stuff. Nice for model a hotrods, vehicles, and they are better quality then after market.
Nice work. . |
