Old 10-14-2010, 10:13 PM   #1
rattlesnakehoey
Default Where art thou diff centres?
Greeetings Fordbarners, My stock flat 6, 3 on the tree (manual gearbox) propelled 49 Coupe pulls like a Trojan but revs too hard on the highway due to 3:7 to 1 rear end. I beleive that later '55-'55 Fordomatic Fords ran a 3:2 to 1 rear end. Where can I get hold of one? all leads appreciated. cheers from Downunder.
p.s. I have just checked over/detailed/ re installed eng/trans & would prefer to avoid the more complex route of replacing with overdrive box or Mustang, etc, rear.
rattlesnakehoey is offline   Reply With Quote
Old 10-15-2010, 09:20 AM   #2
V8 Bob
V8 Bob's Avatar
Default Re: Where art thou diff centres?
Not sure about '52 and up, but here are the ratios offered from '49-'51. The Fordomatic and it's higher gears came out in '51.
Here is the complete listing of ratios and part numbers taken out of the "green" book.
Pass Car removable carrier:
'49-'50- 8A 4209-B 3:73
'49-'50- 8A 4209-D 4:10
----'49- 8A 4209-F 3:73
----'49- 8A 4209-G 3:73
'49-'51- 8A 4209-J 4:10
----'51- 1A 4209-A 3:31
----'51- 1A 4209-B 3:54
Station Wagon "Dana" style:
'49-'50- 8M 4209-B 4:27
'49-'50- 0M 4209-- 3:92
----'51- 1M 4209-A 3:92
----'51- 1M 4209-B 4:27
----'51- 1M 4209-E 3:54
Old 10-15-2010, 11:43 PM   #3
rattlesnakehoey
Thanx fer the info Bob, I am digging your B roadster
Old 10-16-2010, 03:37 PM   #4
ford1
send me an email at [email protected] and i will send you an attachment with a lot of ford rear end info, it might be useful
ford1 is offline   Reply With Quote
Old 10-18-2010, 09:17 PM   #5
rick55
rick55's Avatar
You sign off as being from downunder. If this is Oz the 3.2 diffs are behind auto Customlines 57-59.
Another option is to get the diff out of a Centura that was fitted with the 6 cylinder hemi. These are a four pinion Borg-Warner and have the Ford bolt pattern.
Hope this helps.
Rick
West Australia
1958 Ford Mainline Utility, 1955 Ford Tudor Sedan
Anyone who stops learning is old, whether at twenty or eighty. Anyone who keeps learning stays young. The greatest thing in life is to keep your mind young.
Henry Ford
rick55 is offline   Reply With Quote
Old 10-19-2010, 06:07 PM   #6
rattlesnakehoey
Thanx Rick, Your Star Model Mainline looks great. (getting rare)
Old 10-20-2010, 08:41 PM   #7
rick55
rick55's Avatar
I never mentioned in my earlier post, but Cusso Bill will set you in the right direction in NSW.
Vern Gitsham is the man in Victoria.
If you are in the West I may be able to help.
Regards
Rick
West Australia
Henry Ford
