03-28-2016, 11:47 AM | #1 |
Installing a 40 convertible top
I talked to Lebaron Bonney last week about ordering their convertible top for a 1940 convertible, and installing it myself. I'll admit, they made me feel most comfortable that this was something I could do with good results at home in my garage. That being said, these guys are experts, and I've never done one. I've done all other phases of restoration except a top.
I'm looking for suggestions from those that have done this job and maybe some encouragement, or not, on if I should tackle this or take it to a shop. I'm at a stage in my life that I hate to shop anything out because of ridiculous lead times and poor workmanship. Thanks |
03-28-2016, 12:06 PM | #2 |
Re: Installing a 40 convertible top
03-28-2016, 12:09 PM | #3 |
I have never gone one in these years, but have done FOX mustanges. Some of it is easy and other parts not so much. Guess I would have to say they came out OK, but far from perfect. So, may depend on how picky you are about the final results. I'm fairly sure you can do it yourself, but I would guess you would also be able to tell a difference in the final result vs a professional install.
03-28-2016, 12:19 PM | #4 |
I have done 4 tops from LB. After taking one of my projects to a local guy who was supposed to be top notch and watching what he did, and encouragment from "TJ" on here on the Fordbarn I decided to take it on myself.
LB's instructions are very detailed and complete. If you go slow and ask questions if you have an issue you should have good results. My first one was decent and they got better as I developed more skill. You cannot rush the job and need to check your work often. I say give it a try. |
03-28-2016, 12:36 PM | #5 |
I did my '34 roadster with a top from LB. It's the only one I ever did and it turned out alright. Your 1940 will be a little more challenging but as roadster36 says take your time and ask questions if you run into problems. I'm sure you'll do fine and will be pleased with the results. Good luck with it!
Doug. |
03-28-2016, 12:48 PM | #6 |
I would also strongly suggest you have LB leave the snaps OUT of the material so you may install them exactly where needed. You will be sorely disappointed if the female snaps do not match the location of your body male snaps. There are many "tricks" do installing a top with beautiful results. If you do decide to tackle this task, I will help you though it as needed. Mike Kubarth
03-29-2016, 06:22 AM | #7 |
On my LB top you better be careful not to pull too tight at first for it will change your door opening.You can pull the first pads too tight and you can't shut the door.That is the only problem I had.But I got the whole leather kit from them and had them change the color of the top to match the interior.Just me but fine stuff
03-29-2016, 06:34 AM | #8 |
I put 3 on my 48, forget the tacks especially if you are working alone. Buy yourself a good air operated staple gun that will shoot 1/4 to 1/2 inch staples and at least 3/8 crown. L B no longer puts the snaps in the canvas so you will have to do it yourself . I bought a hand held fastener at Jo Ann's fabric store, the 2 piece gadget they give you with the kit is worthless. I let the canvas lay out on the frame for a couple of days to get some of the wrinkles out of it. Stretch it out good before you tack or cut. Good luck
03-29-2016, 07:13 AM | #9 |
Thanks All for some great advice. I'm gonna give it a shot!
