Old 02-16-2019, 11:33 PM   #1
redmodelt
redmodelt's Avatar
Default line going to timing gear cover 46 V8
One of Tom's customers brought his A hot rod to the shop on a trailer so he could get help with questions about the body. The engine is a 46 V8. On the timing gear cover, drivers side there is a tube it is cut off that goes in to the casting on left of top. Right now it is just a stub of tube being held in with a flare nut. What might it be? And were did it go to? He hadn't noticed it and was not sure himself. I looked at the Green book, but not knowing what it was did not find it.
Thanks
Old 02-16-2019, 11:43 PM   #2
Tinker
Tinker's Avatar
Default Re: line going to timing gear cover 46 V8
On a 38ish it goes to the from the dizzy to intake manifold between the the 5-6 cylinder.
1938, It is a smaller line then the 1/4" fuel copper line.
Vacuum to distributor brake. Later through the timing cover.
Old 02-17-2019, 12:08 AM   #3
redmodelt
redmodelt's Avatar
Ok good, it not an oil line and will not be needed for his application. Thank you very much, that is good news that I will pass on to him
Old 02-17-2019, 11:17 AM   #4
cas3
as stated its the vacuum for the distributor. if he has the stock intake manifold the line is available from the vendors. if you need to make a custom line, those are special fittings that crimp the line when tightened up to seal. only place i found any was nos at 3rd gen auto
Old 02-17-2019, 11:54 AM   #5
redmodelt
redmodelt's Avatar
It has custom headers, aluminum intake, 2 97's, Edmond heads and Edmond air cleaners. The distributor has been updated too so no vacuum needed, hole will just get plugged.
Thank for the information.
Old 02-17-2019, 01:22 PM   #6
JSeery
JSeery's Avatar
You said "drivers side" and "timing cover", that has nothing to do with the distributor. I would guess it is the return line from an early by-pass oil filter. If the filter is removed then the hole can be plugged. The original kits used a banjo fitting and the instructions routed it to the passenger side, but I would think you could mount it elsewhere. Does it look like it is a factory type of connection into the timing cover or a modification?
Note: Bad day at the ranch, LOL. This is all kook-kook.
Old 02-17-2019, 03:09 PM   #7
cas3
jseery, are you drivin in england, or drivin in america?
Old 02-17-2019, 06:02 PM   #8
ford38v8
ford38v8's Avatar
JSeery, All answers so far have confirmed vacuum brake line.
Does this mean you don't bother reading the opinions of others?
Alan
Old 02-17-2019, 06:43 PM   #9
Lawson Cox
Lawson Cox's Avatar
I'm with JSeary. That is a return line from the bypass filter. No kidding.
Old 02-17-2019, 06:49 PM   #10
ford38v8
ford38v8's Avatar
JSeery's picture is the oil filter line, agreed, and is on an earlier engine with the football distributor. The engine in question is a '46 with the rabbit ear distributor.
Alan
Old 02-17-2019, 06:52 PM   #11
JM 35 Sedan
JM 35 Sedan's Avatar
On my '46 to '48, 59 series engine, the stock timing gear cover has a threaded hole on top left side that accepts a vacuum line, and the opposite end of this line connects in the intake manifold. There is a cast or drilled hole inside the timing gear cover that completes the vacuum connection through a small hole in front of cover to a small hole in back of the crab/rabbit ear type distributor. This completes the connection to the vacuum brake inside the distributor.
The oil filter return line was connected to a threaded fitting on the left sidewall of the oil pan.
John
Old 02-17-2019, 07:14 PM   #12
redmodelt
redmodelt's Avatar
"Does it look like it is a factory type of connection into the timing cover" Yes it is inline with a rib cast in the cover. Not for a banjo fitting, small flare nut and maybe 1/4OD tube.
Old 02-17-2019, 08:00 PM   #13
JSeery
JSeery's Avatar
Just one of those days I guess! What can I say!! Doing too many things at once and go a little kook kook.
Think you can see the line from the timing cover to the base of the carb in these photos.
Old 02-17-2019, 08:16 PM   #14
JSeery
JSeery's Avatar
I read them, but didn't help in my state of confusion on this one, LOL
Old 02-17-2019, 08:36 PM   #15
redmodelt
redmodelt's Avatar
See image for location.
Old 02-17-2019, 08:50 PM   #16
JSeery
JSeery's Avatar
Yep, I posted several photos above that shows the route of the line from that fitting to the base of the carb. If you are not running the original distributor it is fine to just cap it off.
Old 02-17-2019, 09:47 PM   #17
cas3
its ok jerry, i never screw up, but i understand some folks do once in a while. we seldom get a chance to catch you though !
Old 02-18-2019, 12:09 AM   #18
ford38v8
ford38v8's Avatar
I thought I was wrong once, but I was mistaken!
Alan
Old 02-18-2019, 12:21 PM   #19
Bored&Stroked
Bored&Stroked's Avatar
It is okay . . . sometimes we jump to a "confusion conclusion" and once that cements itself into our reptilian brains, it takes a huge amount of work to dislodge it! (Some would claim a complete mental reboot is required). Ask my ex wife how I know such things! LOL
