09-13-2015, 04:00 PM | #1 |
Steering Column Bearing
My friend has a '36 Phaeton and he asked me to post the following; He replaced the rubber bushing on the steering column just under the steering wheel. Recently the steering has gotten tight. He squirted some lubricant under the horn button which worked for a short time. He read an old article that showed replacing the rubber bushing with one that had a bearing and was called a Dans bearing. Does anyone have any information on this product? It is supposed to improve the steering. All replies are appreciated. Stan.
09-13-2015, 04:56 PM | #2 |
Re: Steering Column Bearing
There are several ways to do this so you will get a lot of responses. Many local hardware stores carry a replacement "wheel barrow" bearing which can be used. Or,(a better way), some Ford dealers still stock parts C3DZ-3517A and B1AZ-3518A. In either case the cost is much less than $10. Note the pictures. The pencil view is the hardware bearing, the others are of the Ford bearing. The best part is you don't need a deep pocket.
Tom |
09-13-2015, 06:53 PM | #3 |
Dan Brusegard, 763-533-9879, [email protected]
09-13-2015, 08:46 PM | #4 |
