Old 03-09-2024, 10:41 AM   #21
petehoovie
petehoovie's Avatar
Default Re: Potvin cams
Originally Posted by deuce lover View Post
32 Cam just listed for sale on the HAMB
https://www.jalopyjournal.com/forum/...-sale.1311929/
Old 03-09-2024, 02:44 PM   #22
Tim Ayers
You need to check with your cam grinder if they will do a steel cam. Not every grinder can or will.
Old 03-09-2024, 03:43 PM   #23
3W Hank
Tim,
I has a 32 core in USA if I like go that way.
Pete1will do one but said, be avare.
But I has this cam now as showed.
I has NOS 8AB 46 gram lifters and a set of titan 5/64 stem valves ( super light ) and will use Lincoln springs ( always did like the name )
That will read nice and be nice to cam.
I will use a straight cam gear if I can find one ( ideas of source )
I has a 8AB cover and Cirello has got me a longer axle in my early Scintilla so cover get the centre steady rest to magnet.
Plan use std oil pump, or is HV needed ?
3W Hank is offline   Reply With Quote
Old 03-09-2024, 04:34 PM   #24
Ronnieroadster
Ronnieroadster's Avatar
If this is a 32 cam a picture of the cam journals would verify it. Not so sure from the look of that cast area between the lobes midway.
Ronnieroadster
I use the F word a lot no not that word these words Flathead , Focus and Finish.
"Life Member of the Bonneville 200 MPH Club using a Ford Flathead block"
Owner , Builder, Driver of the First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 in one and a half miles burning gasoline.
First ever gas burning Ford flathead powered roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH
Old 03-09-2024, 04:47 PM   #25
3W Hank
The oil core slitz on the journals, I think that is a good indication.
Food for the history.
Old 03-09-2024, 05:00 PM   #26
Bored&Stroked
Bored&Stroked's Avatar
That cam does not look like a 32 cam - appears to be cast. Though what is weird is that the whole back of it is solid . . . so I have no real clue!
Heck, I would not want it anyway - why go through all the work to "finish" the rest of it. If It was going to do that, I'd buy a chunk of 8620 AQBQ and start a billet cam from scratch.
Old 03-09-2024, 05:05 PM   #27
KiWinUS
KiWinUS's Avatar
Ronnieroadster is correct. It’s a cast cam.
1932 Steel cams are flat on the front with just the distributor drive slot. Cast have the circle as you can see on the front of cam pictured.
Old 03-09-2024, 05:05 PM   #28
Tim Ayers
I agree with Ronnie & Dale. That "rough" section showing in the pictures between the lobes looks cast.
Edit: Tony confirmed
Old 03-09-2024, 08:42 PM   #29
Pete
Pete's Avatar
It is an early cast core.
It is a roller grind because it has inverted flanks.
It is NOT a radius lifter grind because of the shape of the toe.
It does NOT have enough lift to be a serious race grind unless it was for an Ardun setup.
Old 03-10-2024, 11:13 AM   #30
3W Hank
https://kustomrama.com/wiki/Bill_Jenks
