Old 03-26-2021, 08:26 AM   #1
jimTN
Default 33/34 side mirror brackets
Has anyone started production of those mirror brackets for 33/34 Fords that attach under the cowl lights?
Old 03-26-2021, 03:58 PM   #2
Lawrie
Lawrie's Avatar
Default Re: 33/34 side mirror brackets
Not here, BUT my mate Kpar made the best setup for a side mirror on his 33 that I ever saw, He may post some picks of it.
Lawrie
Old 03-26-2021, 04:31 PM   #3
Steve Staysko
Steve Staysko's Avatar
Not a Ford but I love these mirrors coming off of the Packard Head light brackets.
Steve Staysko is offline   Reply With Quote
Old 03-27-2021, 02:03 AM   #4
deuce lover
deuce lover's Avatar
Got to have good eyes with those. Here is what I did on a '33 I had.Car is a standard so no cowl lights.Hate the clamp on style so not many options. Instead of drilling a big hole I made a plate that the mirror is attached to securely then the plate mounted on the door.The curve of the arm kinda goes with the curve of the door handle.
Old 03-27-2021, 12:15 PM   #5
cas3
Nice job Deuce lover
Old 03-27-2021, 12:32 PM   #6
blucar
blucar's Avatar
I don't care for the original mid 1930 Ford style of rear view mirror brackets. I used a pair of late '60's Volks Wagon door hinge pin mirrors on my '36. The fit is good on the original Ford hinges, using the VW pins...
Bill.... 36 5 win cpe
blucar is offline   Reply With Quote
Old 03-27-2021, 02:19 PM   #7
Rustyspokes
Rustyspokes's Avatar
I made my own Mirror Assembly that attaches to the shaft of the Cowl Lights that goes thru the body, made it up of Stainless steel 3/8 ths SS Rod and a piece of SS plate, that I shaped and drilled a hole for the Cowl Lamp shaft cut a slot in the end of the SS rod and put the plate in the end, SS Rod welded after grinding both the SS rod and the Plate, gave the rod a bend to suit the mirror out from the Body, they work fine, a bit of vibration so put a small piece of rubber foam against the Cowl Lamp to steady the mirror work well, hope you can follow my Description ... R.
Rustyspokes is offline   Reply With Quote
Old 03-27-2021, 03:14 PM   #8
deuce lover
Thank you cas3 !
Blucar, Your system won't work on a 33-34.
Old 03-27-2021, 03:47 PM   #9
jimTN
There was a thread here on the barn about a year ago that someone was considering making these brackets for the Cowl lights and mirror.
Old 03-27-2021, 04:04 PM   #10
B-O-B
B-O-B's Avatar
I mounted mine to the cowl just below the cowl lamps . Swan neck mirrors from Bob Drake. Work great as the mirror curves around the light. Steady as a rock,1 mounting hole & smaller hole for smaller bolt to keep it from rotating. Got pics to follow, maybe!!!
B-O-B is offline   Reply With Quote
Old 03-27-2021, 05:15 PM   #11
Ian NZ
Ian NZ's Avatar
I got sick of adjusting the outside mirrors all the time on my 32 -3/W specially the L/H one on a R.H.D car so I bought English Tex accessory mirrors one with a flat glass for drivers side and one with a convex glass for passengers side. The beauty of the Tex outside mirrors you can tighten them right up so they will not move after you have adjusted them. I had to make up new shafts to attach them to the Lesco door edge bracket.
Ian NZ is offline   Reply With Quote
Old 03-27-2021, 06:51 PM   #12
Kpar
Kpar's Avatar
I just made up a bracket to clip under the inner door edge with a couple of short screws at the top. Drill a hole at top of bracket for mirror arm. All done with window garnish off. Use a length of wire through the mirror hole to avoid dropping bracket into the door cavity. (Bugger)
Kpar is offline   Reply With Quote
