Old 01-16-2019, 08:57 PM   #1
chrs1961815
chrs1961815's Avatar
Default Roadster Door Knob
So I just took these two door knobs off of my AR28 Roadster and they are different from others I have. The one that was on my car is on the left and it has an octagonal shape. The one on the right is the other one I have that has a hexagonal shape. There is also some differences on the top and the base. So my question is, are the ones that were on my car a thing of early 28's? I couldn't find anything about it in the judging standards or anywhere.
chrs1961815 is offline   Reply With Quote
Old 01-17-2019, 07:17 AM   #2
updraught
updraught's Avatar
Default Re: Roadster Door Knob
They are Vintique. Buy them on eBay.
updraught is offline   Reply With Quote
Old 01-17-2019, 08:21 AM   #3
Mike Peters
Mike Peters's Avatar
Chris: I just looked at the knobs on our 28 Phaeton. All 4 are repros, probably from Vintique. The head is 8 sided, like the one you have on the left of your photo. It fits a 5/8' open wrench, but NOT an 8 point 5/8" socket. So the mystery comes with your 6 sided door latch knob. Is it original? Like you, I couldn't find anything in the judging stands either. Can anyone else shed some light here?
Mike Peters is offline   Reply With Quote
Old 01-17-2019, 03:20 PM   #4
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
If matching knobs are your BIG PROBLEM, you're a BLESSED MAN!!!
Bill Laffin'
"THE ASSISTANT GURU OF STUFF"
Old 01-17-2019, 03:51 PM   #5
Synchro909
Synchro909's Avatar
I'm kinda with Bill. If there is nothing in the judging standards, it doesn't matter which you use - you won't lose points either way.
Old 01-17-2019, 05:40 PM   #6
figment
I have an original knob that is 8 sided and is 9/16 wrench size . The top has the look like the one on the right with the double bump .
figment is offline   Reply With Quote
Old 01-17-2019, 07:47 PM   #7
160B
160B's Avatar
FWIW
Looking at the RG&JS I would say the octagonal lever arm knob is correct. Look at the attached RG&JS 12-10 revised 2016 item "W".
1931 160B & 1931 68B
If you don't have time to do it right the 1st time, how do you have time to do it the 2nd time?
160B is offline   Reply With Quote
Old 01-17-2019, 08:06 PM   #8
updraught
updraught's Avatar
I've only seen round brass ones in the wild.
What does the larest JS say for Canadian ones?
Old 01-17-2019, 08:14 PM   #9
Synchro909
Synchro909's Avatar
Prolly nuttin!
Old 01-17-2019, 08:30 PM   #10
160B
160B's Avatar
What does the latest JS say for Canadian ones?
RG&JS 12-10 Revised 2016 1928 Roadster, Phaeton (door handle lever arms nickel plated through 6/28 then painted black)
RG&JS Canadian F does not have any information on Area 12 Miscellaneous Interior Hardware
Old 01-17-2019, 09:31 PM   #11
updraught
updraught's Avatar
Thanks.
Snyders has a bit more under closed car
https://www.snydersantiqueauto.com/inside-door-knob
