Old 01-12-2019, 07:50 AM   #1
56yblock
56yblock's Avatar
Default problem with coil
hello guys
i had a problem with my coil ,
she burned with the wiring ,from the coil, to the ignition cap distributor
does anyone knows where the problem come from?
56yblock is offline   Reply With Quote
Old 01-12-2019, 12:09 PM   #2
56yblock
56yblock's Avatar
Default Re: problem with coil
i post the pics
Old 01-12-2019, 12:45 PM   #3
50fordcoupeman
50fordcoupeman's Avatar
I had one do that also. Never did figure out what happened. I replaced the coil and wires involved and it was still ok when I sold the car. Coils can be strange beasts!!
50fordcoupeman is offline   Reply With Quote
Old 01-12-2019, 02:27 PM   #4
KULTULZ
KULTULZ's Avatar
Post Re: problem with coil
What I am thinking (scary) is high secondary IGN resistance , either plug wires and/or plugs. Maybe need to perform a resistance test on the wires. What type of plug are you running? Points or PERTRONIX?
And then again it might just be a CHINESEIUM parts failure.
- WHY IS IT ... -
... that everything you buy in the grocery store is either wrapped in or contained in plastic but the government doesn't want you to carry it out in a plastic bag?
WONDERING IN W(BY GOD)V ...
DIAGNOSED CDO - (OCD In Correct Alphabetical Order)
KULTULZ is offline   Reply With Quote
Old 01-12-2019, 05:51 PM   #5
Rusty_S85
Rusty_S85's Avatar
I had that happen on my truck with a Duraspark II. Did it once so I don't know but it was with a set of 9mm Ford Racing plug wires and motorcraft copper plugs. I always wondered if it was just a defective coil wire.
'56 Ford Fairlane Town Sedan - 292 Y8 - Ford-O-Matic
'78 Mercury Cougar XR7 - 351W - FMX
'82 Ford F150 Flairside - 302 - C6
Rusty_S85 is offline   Reply With Quote
Old 01-12-2019, 06:05 PM   #6
dmsfrr
dmsfrr's Avatar
I'm guessing the hi-voltage wire from the coil to the distributor was old or damaged and it's resistance was much too high, so the spark leaving the coil found an easier path to ground, across the top of the coil. Possibly to the "-" wire for the distributor?
Old 01-12-2019, 06:07 PM   #7
KULTULZ
KULTULZ's Avatar
Could have been a coil wire, cap or rotor and wires/plugs.
- WHY IS IT ... -
Old 01-12-2019, 06:14 PM   #8
Rusty_S85
Rusty_S85's Avatar
Possible, but I changed just the wire out and it never did it again.
Wont be a problem for me when I put my new engine in, I got a new dist for the truck with a steel gear for a roller cam and I have a new NOS cap, cap adapter, and a motorcraft rotor to go on the new engine.
I just thought it odd that it just did it with no sign. It didn't burn it two on mine it just when I pulled the coil wire off it actually fell apart and was no good then. Think I was pulling the wire off to pull the coil to have a easier time pulling the valve cover.
Old 01-13-2019, 06:35 AM   #9
56yblock
56yblock's Avatar
thanks for the answers ,i changed by the new one and now it start and runs good, maybe i'll must to change the points and the condenser?
Old 01-13-2019, 08:09 AM   #10
56yblock
56yblock's Avatar
even with the burned coil the car to restart but there were small sparks + or - terminals, is it strange?
Old 01-13-2019, 12:26 PM   #11
dmsfrr
dmsfrr's Avatar
Not strange at all. The burned / carbonized surface of the coil is now more conductive than it was, it's no longer an insulator.
You need a new coil, and all new spark plug wires, if the condition of the coil wire is any indication.
