Old 09-16-2014, 09:57 PM   #1
Ian Curtis
Ian Curtis's Avatar
Default Axial Play in Water Pump Shaft
Hi All,
This previous weekend I went in a 130 mile round trip journey, which is far & away the most I've driven my truck. Made it to the destination & back with no issues, but when I parked the truck there was a serious drip out of the packing nut. It's always dripped a little, so I squeezed in some grease and tightened it a bit and walked away, but a half hour later there was a sizeable puddle on the floor with maybe a drip per second coming from the block. I eventually discovered that if I pushed "in" (towards the block) the shaft moved between a 1/16 and an 1/8 of an inch & the leak stopped.
Is this a sign of something more serious, or do I need to just tighten the packing nut until it stops dripping or replace the packing?
Ian Curtis is offline   Reply With Quote
Old 09-16-2014, 10:37 PM   #2
Drive Shaft Dave
Default Re: Axial Play in Water Pump Shaft
The end play should be held to .006, There is a collar that the vendors sell that fits behind the fan ,held by a set screw. The boss inside the head that is used to control the end play is worn down. There are other ways to fix this but the collar is probably the simplest.
Drive Shaft Dave is offline   Reply With Quote
Old 09-17-2014, 12:35 AM   #3
Chuck Sea/Tac
Chuck Sea/Tac's Avatar
You probably need to repack the pump, and maybe replace the shaft, to stop the leaking, and install the collar to prevent movement.
Old 09-21-2014, 06:17 AM   #4
billybronco1
I need to understand this pump end play more. My pump does not leak for short rides and not sure about long rides because I have not done that yet. I have almost a half inch end play if I slide the shaft back and forth. This does not seem right and I need to know what to do.
Also the car has a six volt alternator and I was wondering how much play should be in the fan belt - thanks
billybronco1 is offline   Reply With Quote
Old 09-21-2014, 07:06 AM   #5
Ed Saniewski
Ed Saniewski's Avatar
The collar will keep the shaft from sliding back and fourth,so it will keep the shaft at the pulled out toward the radiator. Ian, if you have to push in on the shaft to stop the leak, try tightening up the packing just until the leak stops. Do not over tighten it or you will score the shaft. If it still leaks then do as Chuck said and replace the shaft. Some one prior probably over tightened it and scored the shaft.
Model A Ford Club of New Jersey
http://www.mafcnj.org
Model A Pick Up Owners and Enthusiasts
https://www.fordbarn.com/forum/group.php?groupid=5
Ed Saniewski is offline   Reply With Quote
Old 09-21-2014, 12:17 PM   #6
billybronco1
Where does one buy this collar do you have a part number?
Old 09-21-2014, 11:22 PM   #7
Bill Cilker
Bill Cilker's Avatar
Do not use the collar if you are running a plastic fan with the steel hub. There is not enough room between the water pump housing and the steel hub when it is seated properly on the shaft.
Bill Cilker, Jr
Unrestored 190A Victoria
45B, 160B & 189A
Victoria Association President
Bill Cilker is offline   Reply With Quote
Old 09-22-2014, 05:32 AM   #8
Ed Saniewski
Here is a link to Brattons
WATER PUMP SHAFT COLLAR
For Year(s): 28-31
Before installing the fan on the shaft, slide the teflon washer followed by the steel collar up to the front of the pump housing. Use the set screw to secure it in place. This will eliminate all the shaft endplay, which can disturb the packing causing a leak. Collar will not be seen when the fan is installed. Set includes teflon washer steel collar and set screw. This collar will not work on the repro 6 blade fan.
Part #12500
Old 09-22-2014, 05:39 AM   #9
Ed Saniewski
Let's try this
http://www.brattons.com/uploads/imag...arge/12500.jpg
Old 09-22-2014, 10:03 AM   #10
Ian Curtis
Ian Curtis's Avatar
Ed, is that your Piet in your profile picture? Cool shot either way!
On further inspection, I think the problem was me. I believe I thought I was tightening the packing nut and I was actually loosening it and had backed it off 1/2 a turn. Properly tightened and not leaking now...
Old 09-22-2014, 01:05 PM   #11
Russell in Tulsa
Yes, Righty Tighty, Lefty Loosey.
Russell in Tulsa is offline   Reply With Quote
Old 09-23-2014, 01:47 PM   #12
billybronco1
Okay I plan on buying this collar looks like an easy fix for shaft end play - thanks. My car has a six volt alternator running an A8620 belt. The alternator is adjusted out all the way and I still have quite a bit of slop in the belt maybe 2". First how tight should this belt be and should I get the next size shorter belt if there is such a thing or a longer adjustment arm on the alternator?
Old 09-23-2014, 01:50 PM   #13
stewwolfe
stewwolfe's Avatar
Alternators don't like loose belts. You should go with a shorter belt.
'31 40B
'31 68C
stewwolfe is offline   Reply With Quote
Old 09-23-2014, 02:30 PM   #14
billybronco1
I do realize that on today's conventional cars but I was concerned on over tightening and the effect of premature wear on the water pump shaft bearing.
Has anyone used a smaller belt there is more to it then just the length - What would the part number be for a 1" shorter A8620 if there was such a thing?
Old 09-23-2014, 03:16 PM   #15
CarlG
CarlG's Avatar
I use a cogged belt such as BX40. Seems to grip the smaller alternator pulley with less tension than the solid belt does.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 09-23-2014, 04:37 PM   #16
billybronco1
I assume a BX40 has a total length of 40" is that correct? Is that the actual part number?
Old 09-23-2014, 04:56 PM   #17
CarlG
CarlG's Avatar
Goodyear Engineered Products Torque-Flex V-Belt, BX40, Cogged, 0.66" Top Width, 0.41" Height, 40" Approx. Inside Length (NAPA has their own part #, but just ask for BX40)
Alaskan A's
Old 09-23-2014, 05:01 PM   #18
billybronco1
Okay great I found the web site I need something a little shorter and they have a BX39 that is 1" shorter, should do the trick.
Old 09-24-2014, 06:50 AM   #19
billybronco1
Can the fan blade be removed with out removing the radiator and then install the collar it looks pretty tight in there?
Old 09-24-2014, 07:37 AM   #20
Joe K
Joe K's Avatar
Generally not due to the extended length of the pump shaft (which is nearly to the backside of the radiator.)
Although one might try to play a game of undoing (somehow) the upper radiator hose connection and prying the radiator forwards to gain additional clearance. You may end up with the radiator split in pieces though. An outright removal is probably best.
Of course if the radiator is removed - then one is free to install an "ultimate" pump which, which it's cartridge/forward bearing, needs no attention to free play (it's built in.) Or even do an extended shaft/cut down to fit pump rebuild.
In a lot of ways I consider the plastic donut a "temporary fix" - and one I might not normally choose to do on that account. But given a choice between driving and not driving - it would be an easy change of mind for me to install. And I would be encouraged by others success with this option.
Joe K
Shudda kept the horse.
