01-30-2017, 12:28 PM | #1 |
Drilling hubs and drums for MT drums...
I bought a pair of MT drums and I need the drill sizes needed for the hubs and drums for the new longer studs. I should have them somewhere but it would take forever to find the info. This would be for '40 hubs on the rear. Thanks!
01-30-2017, 03:33 PM | #2 |
Re: Drilling hubs and drums for MT drums...
Do the studs have the id numbers on them? I used the Speedway drums and used 610-109 studs. They fit the drums.
01-30-2017, 04:34 PM | #3 |
Pete,the studs press into the hub and have a shoulder that fits in the drum. The holes in the drum are the right size. Inhave always used their hubs,so I do not know size to drill. Someone may know or givea call to MT.
The drums do not get swaged. John |
01-30-2017, 05:58 PM | #4 |
measure the smooth part on the stud, and drill a hole that size. the splines will "broach" they're way in. do a test hole on some steel and check the fit. use a press to install, and check them often when you start driving it.
01-30-2017, 06:18 PM | #5 |
There should be holes already. Most are already the correct tight fit. If they did need to be resized, it would likely need to be reamed to a proper fit. Drills are not an accurate way to resize and not all reamers are either. I used specific size non adjustable reamers for this type of stuff otherwise it goes in the mill. If they are outy type drum/hub set ups, a person can use the press in studs for the hub only and fit up the drums like a modern set up as was mentioned.
01-30-2017, 06:22 PM | #6 |
Paul in CT |
01-30-2017, 08:59 PM | #7 |
Talk to MT. They recommend drilling then reaming to dimension. They are modern studs and not installed like the old fashioned ones.
41 woodie https://41fordwoodie.weebly.com/ |
01-30-2017, 09:59 PM | #8 |
For the 40 rear hubs, the existing holes need to be very accurately drilled and reamed to .600"diameter. Use the Dorman 610-234 stud (Raybestos 5351B). The knurl on this stud is a bit long and could be shortened .060 if you are seeking perfection, but they seem to work fine without modification. As mentioned, you could also use the 610-109 stud - the knurl on it is the correct length but a bit larger in diameter than the 234 stud. I haven't used the 109 stud so don't know if it might require reaming the hole a bit larger than .600" to get a proper press fit.
Those who do not move do not die, but are they not already dead? |
01-31-2017, 08:12 AM | #9 | |
