10-21-2018, 06:15 AM | #1 |
4 blade fan woble
I want to know if anyone has a good method to fix a 4 blade wollard out fan hub? thanks, steve
10-21-2018, 07:25 AM | #2 |
Re: 4 blade fan woble
Replace with new aluminum two blade fan and leakless water pump.
Two more problems solved. Enjoy. |
10-21-2018, 07:30 AM | #3 |
WHN is absolutely right!! Why do you need a four blade fan? Do you have some sort a hot rod that you need a four blade fan?
31 Tudor 66 Bonneville 57 Chevy pickup 27 T roadster pick up |
10-21-2018, 08:23 AM | #4 |
The two blades of the airplane type fan is plenty to move the air. Many airplanes only have two blades on a motor.
10-21-2018, 09:56 AM | #5 |
A two blade fan is said to actually move more air than a four blade, according to some one that did an actual study on it.
Bill Worden 1929 Roadster 1929 Briggs Town Sedan 1930 Closed Cab pickup Smith Motor Compressor 1951 Ford F1 High Desert Model A's |
10-21-2018, 10:25 AM | #6 |
10-21-2018, 07:24 PM | #7 |
looking at this closer ,found out that the rivets that hold the hub to the fan (4) were loose. I might try to tighten them up and see how that goes. thanks to all, steve
10-22-2018, 06:35 AM | #8 | |
Old fan blades are known for breaking at speed. The damage that could be done is not worth saving the cost of a new blade. If it happens when you have the hood open, someone could get really hurt. This is a “known” problem with Model A fan blades. Change the blade. |
10-23-2018, 07:16 PM | #9 | |
Otherwise you will take the chance of wiping out your perfectly good radiator. Don't ask me how I know this! (BTW -- I am now using one of those 6-blade plastic fans)
10-21-2018, 07:52 PM | #10 |
Just be warned, if it wobbles too much it could stress or fatigue the blades. Make sure your fan is still in good condition and running in a balanced fashion. I had one of those four blades on my car originally but one of the blades decided to crack and let go. Still have the hood dimple as a reminder.
10-21-2018, 08:27 PM | #11 |
I wouldn't risk body damage. Better to buy the aluminum fan.
