11-14-2017, 10:53 AM | #21 |
Re: Tubular shocks
I couldn't afford the price of original shocks so I just put on Bratton's new shocks that don't need any drilling or modifications to the car. I think they are great and about 1/3 the price.
11-14-2017, 11:46 AM | #22 |
Re: Tubular shocks
I'm just looking for shock numbers so i can get by cheaper yet,
I will built my own brackets |
11-14-2017, 12:06 PM | #23 |
Re: Tubular shocks
Ken's shock kits are great. Also, I've used the Lovejoy/Armstrong shocks with good results on my 32 Model B. They bolt into original holes.
11-14-2017, 12:43 PM | #24 |
Re: Tubular shocks
Have to agree with some of the others here...Ken Davis
11-14-2017, 12:51 PM | #25 |
Re: Tubular shocks
11-14-2017, 01:08 PM | #26 |
Re: Tubular shocks
gabrial 82011 https://www.ebay.com/itm/Shocks-leng...481?rmvSB=true I drilled the holes in the frame then clamped the bracket to the frame and used the drill to mark where the holes were needed and drilled those on the drill press. The 3/8 bar stock I have on hand is quite a bit harder than the frame. I switched steels as the 1/2 in i made the lower brackets out of seemed overkill for the project and took along time to cut and shape with the grinder. I have seen threads where a bracket was made that uses the brake backing plate and longer bolts. With the shock behind the axle. This is just what I dreamnt up one day and it worked out. Not saying its the best or good even I wont know that until its down the road a ways. Just some food for thought. Last edited by mike657894; 11-14-2017 at 01:34 PM. |
11-20-2017, 07:05 AM | #27 |
Re: Tubular shocks
How did you attach the "D" bracket to the rear end? Was it welded to the axle tube?
11-20-2017, 08:29 AM | #28 |
Re: Tubular shocks
Mike,
That Gabriel shock only has 4.11 inch travel. Maybe someone will correct me, but I don't think that is enough travel for the rear suspension. I am fabricating front shock mounts for my 29 Tudor. I'm using a KYB 343138. It is the shock offered by one of the commercial kit makers. It has similar travel, but is stud mount on both ends. I don't think it is long enough to use on the rear. |
11-20-2017, 11:33 AM | #29 |
Re: Tubular shocks
We found that about 10.5" compressed and 17" extended length will work on most A's depending on kit type and bracket locations. Need to allow for spring rate and rebound which we found to be better with non gas assist types.
