Old 09-30-2014, 02:22 PM   #1
bart78
bart78's Avatar
Default Open drive to closed drive trans conversion
I have a 47 pickup transmission. How do I go about converting it to a closed drive?
bart78 is offline   Reply With Quote
Old 09-30-2014, 02:38 PM   #2
Bassman/NZ
Bassman/NZ's Avatar
Default Re: Open drive to closed drive trans conversion
Sell or swap for a 39.
Bassman/NZ is offline   Reply With Quote
Old 09-30-2014, 02:49 PM   #3
Rowdy
Same transmission as the 39. Just need to swap the output shaft and the rear bearing retainer. I am sure some one here ot on the HAMB would gladly swap. If I did not already have the parts for the open drive shaft I would take you up on a trade. I am sure Jim Brieley here on Fordbarn would have the parts you need also. Rod
Do the RIGHT thing - Support the H.A.M.B. Alliance!!!!
Rowdy is offline   Reply With Quote
Old 09-30-2014, 04:21 PM   #4
jimTN
Not! The later pu has modern springs on either side which will not allow the rear end to move as it does with the traverse spring. In addition to the trans. you would have to have a correct ring gear and pinion for the closed type driveline. Not sure of what the torque tube length would be and that is another thing to consider.
jimTN is offline   Reply With Quote
Old 09-30-2014, 04:32 PM   #5
bart78
bart78's Avatar
I am collecting parts for a av'8. And will be putting a f1 crossmember on the frame.
Old 09-30-2014, 04:42 PM   #6
bart78
bart78's Avatar
I don't know yet what rear i am going to use. I'm trying to keep the car as much pre war that I can. Finding whole cars around here is not hard. But finding parts is. Parts laying around get hauled to the scrap yard.
Old 09-30-2014, 04:55 PM   #7
Rowdy
I am gathering parts for the same, but am using a 42-47 pu rearend center section, so I can have an open drive shaft. I have not located a set of 35-36 axle hsgs yet to complete modified narrowed rearend. It will be atleast another year before I need them, so still plenty of time. Thankfully i have a 47 pu transmission in good shape, so that was the easy part. Rod
Old 09-30-2014, 05:15 PM   #8
bart78
bart78's Avatar
There is a lot I have not decided on. I came up on two Mercury v8's. I'm thinking about using one I them. I found a guy with a beat up 41 sedan. And trying to get the rear out of it. And the backing plates and drums and spindles. I would like to use a 32 k member. But I got the f1 crossmember for free. So I'm going to use it.
Old 09-30-2014, 05:26 PM   #9
Rowdy
Sounds like we are on the same budget. I have the 47 pu center crossmemeber from the one I parted out, other than that I would have looked for something else also. So far I have about $470 into the project. It started with a rear coupe section I was given by my Great Uncle when I was helping clean stuff up. Still need to go get the 53 Mainline from that deal. Hopefully that will help with parts I need to buy for the chassis and maybe a replacement right quarter panel. Rod
Old 09-30-2014, 05:41 PM   #10
Charlie ny
The question was simple........convert an open drive trans to closed........a few
relatively available parts and your 'in'. email me bart...cheap too !
Rowdy....you need '35/'36 housings , I have them...struts too !
Charlie ny
[email protected]
Charlie ny is offline   Reply With Quote
Old 09-30-2014, 06:21 PM   #11
Rowdy
If I do not find a set over the winter locally I will let you know. There are 3 sets locally, but they are all still under what is left of the cars. Was on "Junk Jaunt" and at Freemont swapmeet this last weekend and will see what becomes of the leads and contacts in the next few months. Thanks Rod
Old 09-30-2014, 06:57 PM   #12
bart78
bart78's Avatar
Rowdy I'm going to be doing a 29 Roadster. I would like to do a pre war style lakes roadster. Trying my best to do as much of it in pre war ford parts.
Old 09-30-2014, 07:07 PM   #13
Rowdy
Aiming for slightly postwar at the newest. Likely will sell my 37 21 stud and opt for the 59A instead. It was my original intention to use the 21 stud just to be alittle different, but think that idea is headed the other way. Rod
Old 09-30-2014, 08:40 PM   #14
bart78
bart78's Avatar
I keep looking for a good 21 stud. They are hard to come by around here. I don't know where pre war stops. But I figure a 41 engine would be pre war. I like the sound of the 21 stud.
