02-13-2018, 04:48 PM | #41 |
Re: Power Steering Make Up 56 Wagon
Also, as I mentioned before, the '55/56 bushing kit did not come with the steel tube sleeve as they were not originally designed for them.
The 1957 and later ram cylinder did have a factory installed sleeve which was an improvement (protecting the end of the ram cylinder shaft in the event the rubber bushings were damaged). So be warned that if your ram cylinder is a '55/56 unit, you must be diligent in inspecting the bushings periodically for wear and replacing them before they get too bad OR the ram cylinder shaft will rest and slide on the cast iron idler arm bracket, damaging the shaft. More info: Fomoco installed a ram cylinder with an external copper tubing return line up until about mid 1955. The late '55 through 1956 ram cylinder had this return passage internal to the unit. The 1957 cylinders all had internal return passages but the cylinder was a completely different unit that could easily be differentiated from the older '55/56 cylinders just by eyesight. |
02-13-2018, 07:36 PM | #42 |
The biggest problem here is the lack of quality aftermarket parts/kits and wear/lack of effective repair/proper maintenance over the years.
It is just like me, completely worn out...
***** - MULTI-VEHICLE SYNTHETIC TRANSMISSION FLUID - Multi-vehicle transmission fluids are becoming more and more popular in the marketplace. Oil marketers design these fluids for a wide range of automatic transmission types. While they are not licensed by any specific auto manufacturer ... ??? ... enough said ... DIAGNOSED CDO - (OCD In Correct Alphabetical Order)
02-13-2018, 08:41 PM | #43 | |
Does the correct T-bird bracket have a recess for the crush-nut? You mentioned earlier that the full-sized car bracket has that recess. In any case I'll likely leave it alone unless it breaks again. As of now the frame is welded back together with a nut the next size larger & matching flat washer welded inside the frame, for the bottom bolt hole. . Last edited by dmsfrr; 02-24-2018 at 07:53 PM. |
02-13-2018, 08:51 PM | #44 |
K, that's how I repaired my C5 radiator support Assy., used a bolt and nut to start the crushing process inside the frame...
dmsffr, my bracket on the bottom side of my frame does not fit flush, I can see the heads of the crush nuts. Dave, I measured last week when the issue arose from a kit ...junk aftermarket, obviously would not work. My threads are 7/16 x 20, the useable shaft space is 1" and the shaft space at the bracket is in great shape. I ordered the complete kit from Casio and should be here by Fri....Coffee and Cars on Sat., hopefully. My shaft does have a slow drip issue, wonder why it's over $300 to rebuild one? The Ram has to be cut open to replace an inner seal! The outer parts can be replaced but I think I'll wait for a time when I can use a car rack. Also I understand it's difficult to r&r the the seal on shaft end. |
02-14-2018, 05:31 AM | #45 | |
Three main styles for this period- 54/56 FORD 57/59 FORD 55/57 BIRD As long as a previous owner did not swap or switch.
02-14-2018, 05:49 AM | #46 | |
The aftermarket 53/56 kits are not correct. They have incorrectly shaped insulators (appears to be from later 57/ FORD kit). The early insulators are/were conical in shape to fit withing the washers (which are not included) and special relief(s) in the 3351 bracket to control insulator movement. 57/ FORD (not BIRD) was changed in that there was a sleeve used to better control insulator movement. Shown below are three present day vendor kits. The insulators are incorrect on the 53/56 FORD - 55/57 BIRD kit(s). One vendor has two separate style kits shown with the same PN. If they don't know, how are you supposed to know?
02-16-2018, 02:28 PM | #47 |
Here's what is in the CASCO Kit, apparently covers 55 and 56 which have different sized shafts and grommets. Mine I believe are the upper washers, grommets, lower left nut and lock washer. Who needs the other parts, Dave?
Whoops held iPad wrong way! |
02-16-2018, 04:11 PM | #48 | |
If that Casco kit is available, GET IT. It contains all the rubber bushings, washers and nuts for both ends of the ram cylinder. |
02-16-2018, 05:11 PM | #49 |
Installed, Cars and Coffee tomorrow!
Put a Jam Nut on the end, this Unit shakes a bit with engine on and wheel to L and R stops. Silicone grease on grommets. |
02-16-2018, 06:49 PM | #50 | |
The new rubber bushings should be squeezed a fair amount when they're installed. You may need to add a couple washers to get them very snug on the cast bracket. |
02-16-2018, 07:15 PM | #51 |
It jiggles, if the threaded part is 3/4", about half ? is used visualizing from outer washer to stud end. Do grommets absorb the Ram action? They are bulging a bit from 90 edge now.
Think more? |
02-16-2018, 08:24 PM | #52 |
It's a *you've got to be there* sort of thing but the rod shouldn't jiggle or move by grabbing / pulling it with your hands, except the very slightest amount.
Both grommets should have a good bulge in their sides. . Last edited by dmsfrr; 02-16-2018 at 10:18 PM. |
02-16-2018, 09:06 PM | #53 |
Have you looked "at the action" with car motor on and turning steering wheel full stop L and R? , while on stands? What year is your T Bird? I have some room left on threads to tighten more.
Do you know a Fred Sanchez in your area? |
02-16-2018, 09:48 PM | #54 | |
The name Fred Sanchez doesn't sound familiar. . Last edited by dmsfrr; 02-16-2018 at 09:55 PM. |
02-17-2018, 09:10 PM | #55 | |||
Now this is a complete quality kit! Quote:
On your install (3rd attachment), the PAL NUT is not on the threads far enough. It could fall (vibrate) off. My old lady tightens mine...
02-21-2018, 05:33 PM | #56 | ||
Same amount of stress exerted (allowing for vehicle weight). Quote:
Also shown is he 55/57 BIRD bracket (2nd photo). That CASCO kit (combined 3C590 and 3C589) is worth it's weight in gold...
Last edited by KULTULZ; 02-22-2018 at 06:36 PM. Reason: HOPEFULLY TO CLARIFY POST INFO |
02-22-2018, 04:53 PM | #57 | |
That is correct. The first picture shows the factory bracket for full-size cars and wagons. The second picture shows the bracket for T-Birds. dmsfrr NOTICE that what you have on your Bird is a factory manual steering idler arm bracket and a separate cast iron bracket to hold the ram cylinder shaft end. It appears to be a factory Bird bracket with the idler arm bushing collar cut-off of it. Having these separate like this could result in mis-alignment of the ram cylinder with relation to it's proper position on the frame. Do the factory holes in the bracket and frame line up??? |
02-22-2018, 05:59 PM | #58 | |
I'm confused. The PS/idler arm bracket on this '55 Bird is one cast piece (photos below) and looks just like the Macs image that KULTULZ attached above, and also at this link.... https://www.macsautoparts.com/ford_t...g-1955-57.html Last edited by dmsfrr; 02-22-2018 at 06:45 PM. |
02-22-2018, 06:15 PM | #59 | |
He has the correct MTG BRKT (3351) for the 55/57 BIRD. Go back and check his posts/photos.
02-24-2018, 08:04 AM | #60 |
Hey dmsfrr-
I imagine you frequent BIRD only forums a lot. Have you noticed any other 55/57 BIRD failures/complaints such as this?
