Old 09-12-2017, 09:21 PM   #1
Cape Codder
Cape Codder's Avatar
Default Retrive Starter Bendix Bolts
Tried to start A early this evening and only the starter would spin. Am suspecting that the bolts that hold the bendix in place have fallen out. Don't know for sure as I just returned it to the garage and shut it off until tomorrow in the A.M.
Any one have proven methods of retrieving the bolts from the fly wheel housing?
Cape Codder is offline   Reply With Quote
Old 09-12-2017, 09:58 PM   #2
MikeK
MikeK's Avatar
Default Re: Retrive Starter Bendix Bolts
Well, removing the flywheel housing is a proven method but I don't think that's what you are looking for!
I use a fiber optic scope to find hidden things in trannys, engines, and other in-accessible places. Once you spot it then retrieving it with wires, magnets, adhesive on a stick, etc. is much easier.
MikeK is offline   Reply With Quote
Old 09-12-2017, 10:34 PM   #3
160B
160B's Avatar
This is what I have used. Pull the starter and use the grabber with a magnet to fish out the loose pieces.
Four prong grabber with masking tape insurance and magnet for retrieving starter bendix bolt from flywheel housing
1931 160B & 1931 68B
If you don't have time to do it right the 1st time, how do you have time to do it the 2nd time?
160B is offline   Reply With Quote
Old 09-12-2017, 10:35 PM   #4
mike657894
mike657894's Avatar
magnet duct taped to coat hanger.
mike657894 is offline   Reply With Quote
Old 09-12-2017, 11:05 PM   #5
Chuck Sea/Tac
Chuck Sea/Tac's Avatar
I did similar to 160B . I used an old length of drain augar, with a small magnet epoxied to the end. As he said, go through the starter hole, and you'll have the head and washer out, in a couple of try's.
Chuck Sea/Tac is online now   Reply With Quote
Old 09-12-2017, 11:17 PM   #6
Tom Endy
Tom Endy's Avatar
If all the above fails, remove the starter and put a big gob of wheel bearing grease on the flywheel. Slowly rotate the engine and hope the bolts will grab onto the grease,
Tom Endy
Old 09-12-2017, 11:27 PM   #7
Floats
Floats's Avatar
Cape Codder,
My money is on a failed bendix drive spring, rather than the bolts just falling off. Those bolts were obviously tight and secured with locking plates. I realise that they take a lot if beating, but take the starter out before jumping to conclusions.
I have recently had two springs fail , one my Model A and one on the Chevy.
Regards
Chris
Cape Town
28 Model A RPU, 29 Chevy Phaeton, 67 E Type FHC, 67 250SL Pagoda, 83 911 SC
Floats is offline   Reply With Quote
Old 09-13-2017, 06:09 AM   #8
Lona
Lona's Avatar
Had the same problem when I was a teen with my first Model A. An old mechanic told me to roll up a rag, push it through the starter hole and slowly rotate the engine until the rag pushed the bolt back to the starter hole where it and the rag could be removed. Worked like a charm.
Glen
'31 Model A Deluxe Roadster
'31 Chrysler Model 70 Sedan
'88 Pontiac Fiero GT
'36 Auburn Boattail Speedster replica
Lona is offline   Reply With Quote
Old 09-13-2017, 07:43 AM   #9
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
I think Loctite on the threads, helps from losing those BOLTS.
Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 09-13-2017, 01:56 PM   #10
KGBnut
KGBnut's Avatar
I used a strong magnet secured to a string. I stuck the magnet to the flywheel and slowly spun it until I heard a 'clunk." The string was in case the magnet got stuck to the bell housing.
Ken
Style beats speed any day, and with a lot fewer tickets.
KGBnut is offline   Reply With Quote
Old 09-13-2017, 08:11 PM   #11
Cape Codder
THE CONCLUSION!!
I used a flexible four finger retriever tool and on the second try brought it out! Wish I could be that lucky for the Power Ball!!
I did not attempt to retrieve the lock washer as I had enough luck for one day. So I went to a friend that has done a whole lot of work on Model A's and he had the proper lock washer, BUT he informed me that I had the WRONG SIZE spring on this starter (never knew there are two different sizes). So he gave me the proper size spring and two different bolts.
All together and starts well. Off to the New England in the morning.
Thanks to all that gave advice on how to deal with the situation.
Old 09-13-2017, 08:17 PM   #12
stewwolfe
stewwolfe's Avatar
Way to go! Thanks for letting us know what the end result was.
'31 40B
'31 68C
stewwolfe is offline   Reply With Quote
Old 09-13-2017, 10:06 PM   #13
Clem Clement
Clem Clement's Avatar
Yes, there are at least 2 different sizes of the loops at the spring ends.
Old 09-13-2017, 10:21 PM   #14
Big hammer
Glen
Thats the best how to remove hareware in the flywheel housing! except drilling a big hole or removing the motor Thank you old mechanic.
get a bigger hammer tap done
Big hammer is online now   Reply With Quote
Old 09-14-2017, 06:56 AM   #15
john charlton
john charlton's Avatar
I lost my starter drive ,pulled the starter and a Bendix bolt had dropped out . I securely taped one of those super strong button magnets on the bottom of an old speedo cable and went fishing . Caught 4 bolts and various lock washers so you never know what lurks in your flywheel housing !!!
John in the weather is brightening up Suffolk County England .
