Old 05-27-2010, 05:31 PM   #21
Brad in Germany
Brad in Germany's Avatar
Default French dual spark plug head
At Rétromobile in Paris, France last year I saw this rather interesting Model A head. It was made by the "Etablisement Veyet", Lyon, France.
What does the extra set of spark plugs do? I believe it might have been an attempt to squeeze a little more power out of the smaller AF engine that it is mounted on.
The engine is located in central France. His asking price for the entire engine as pictured is 1500 Euro ($1875.-) and he does not know what the condition of the engine is....
Fordially,
Brad
Brad in Germany is offline   Reply With Quote
Old 05-28-2010, 05:09 PM   #22
Bick in New Zealand
Bick in New Zealand's Avatar
Default Re: High compression heads?
Bassman,
I'm running a Winfield head, and have been very pleased with the performance and reliabilty.
Cheers
Bick
Bick in New Zealand is offline   Reply With Quote
Old 05-28-2010, 05:13 PM   #23
Jason in TX
Jason in TX's Avatar
Default Re: French dual spark plug head
Brad - My guess would be that the engine you are looking at was either originally a fancy speed (they have been made with dual spark plugs for speed. Look at the modern Lion Head)
OR an airplane engine head. redundancy is nice to have in the air, and airplanes had two sets of magnetos. One electrical system goes out, switch over to the other and keep 'em flyin'
I also found this on a Harley website: Interesting Info:
In 1917, Liberty Aircraft discovered that simply adding another spark plug to the opposite side of the combustion chamber and increasing the voltage at the plugs would cure detonation and increase power.
The same dual plugging solution was incorporated by Continental and Lycoming in the 1920s and 30s. Primarily used as a safety factor, it also reduced spark plug fouling and detonation and increased RPM..
For exactly the same reasons, your Harley motor can benefit from dual plugging. Dual plugging will “undo” the problems with its combustion chamber design and help your Harley run happily on unleaded gas.
Dual plugging alone of a stock motor will eliminate most detonation, stop plug fouling and hard starting, increase horsepower by five percent or more, increase gas mileage, double spark plug life, and lower emissions. Some tuners have reported six to eight percent increase in gas mileage.
Fordially,
Brad
Drive it like you know how to fix it!
DMAFC / OILERS CC-MC
Jason in TX is offline   Reply With Quote
Old 05-28-2010, 05:54 PM   #24
Pete
Pete's Avatar
Originally Posted by Elrod View Post
I'm a fan of the Thomas head, but mine has what appears to be a Brumfield profile. Runs great. The carbs need just little more tuning but I like the power that it puts out!
That appears to be an original Thomas head as opposed to a Dan Price reproduction.
Dan told me how to modify one of his heads to get 10 to 1 compression.
After welding the chamber up completely you machine it to look exactly like a flathead V8 Edelbrock head chamber.
I ended up with 11 to 1.
Here's a pic of the V8 chambers..The 4 bangers looks identical.
Old 05-28-2010, 06:47 PM   #25
karsyn
Smile Re: High compression heads?
I just put on the Snyders 6:1 head with a touring cam. I can run 65 mph all day and not hear the motor run. Best money ever spent. I also run a 4 speed overdrive.
karsyn is offline   Reply With Quote
Old 06-09-2010, 03:30 PM   #26
Larry Brumfield
In reference to (#11) Aerocraft's comments above concerning a Brumfield Head, go to and please read my posts numbered 10 and 12 on the thread entitled RE: Rear End Noise Update, June 9, 2010. Thanks
Larry Brumfield
Larry Brumfield is offline   Reply With Quote
Old 06-09-2010, 05:10 PM   #27
Bassman/NZ
Bassman/NZ's Avatar
Originally Posted by Bick in New Zealand View Post
Bassman,
Cheers
Bick
Hi Bick,
Are you the owner of the coupe with 16's, and twin carbs etc?
Bassman/NZ is offline   Reply With Quote
Old 06-09-2010, 05:16 PM   #28
1931 flamingo
1931 flamingo's Avatar
Larry, Nice to see you posting on the "Barn" again. Have missed your posts.
Paul in CT
Old 06-09-2010, 05:38 PM   #29
Bob A.
Fordially,
Brad
I have dual plugs on my wife's "Hemi" engine. As far as I'm concern,"It squeezers more money out of my wallet" when I have to do a tune up.
"Some Talk the Walk while others Walk the Walk"
Bob A. is offline   Reply With Quote
Old 06-09-2010, 10:50 PM   #30
V4F
V4F's Avatar
i have tested for compression on 3 different heads .
stock - 55#
5.5 - 75#
6.1 - 85#
hope this helps .......... steve
V4f
V4F is offline   Reply With Quote
Old 10-11-2018, 06:54 PM   #31
Niggled
Are they 94 Holleys and what jet cofigurations are you using. I have a Riley 2 port head and having trouble tuning them. I've been told that the power valves are the wrong size
Niggled is offline   Reply With Quote
Old 10-11-2018, 07:05 PM   #32
Synchro909
Synchro909's Avatar
Originally Posted by Lawrie View Post
What sort of cranking pressure do you get with the 5.5 head.
Lawrie
In my tourer, which you know, Lawrie, I get more than others here have said they get - high 90's. Very close to 100 psi in each. That's higher than I would have expected from 5.5:1 compression ratio but that's what it is! Bores are 60 over, FWIW.
Old 10-11-2018, 07:40 PM   #33
Y-Blockhead
Y-Blockhead's Avatar
Those appear to be Stromberg's.
Old 10-11-2018, 08:28 PM   #34
Tom Foster
Compression (PSI) / 14.7 = compression ratio. Good for rough estimate, no lab glassware needed.
Fearless
Tom Foster is offline   Reply With Quote
Old 10-12-2018, 12:11 AM   #35
old31
x2 with karsyn.
old31 is offline   Reply With Quote
Old 10-12-2018, 11:57 AM   #36
Jim Brierley
Just a comment, the pics posted by Jason, niggled, etc. appears to be more like a Winfield chamber. The original Thomas tended to detonate, Winfields did not. On dual plug heads, I ran a big Hall-Scott (5 3/5" bore) on a chassis dyno years ago. They had dual plugs, one on the left side of the head (OHV) one on the right. Each bank was on a separate switch. At idle there was a difference in RPM when one bank was shut off, at full throttle there was no difference in power!
Old 10-13-2018, 11:47 AM   #37
40 Deluxe
Fearless
That would be a very rough estimate! Nowhere near accurate! Compression pressure is dependent on several variables such as when intake valve closes, cranking speed, engine temperature, and rate of leakdown.
Compression ratio, on the other hand, is based on two simple measurements: the volume of the combustion space with the piston at BDC, and then the combustion volume with the piston at TDC. Then simple division gives you the correct ratio.
