Old 11-19-2019, 07:10 PM   #1
PC/SR
Default Ring gear pins
What type/size/source pins do you guys use to pin the ring gear to the flywheel. The ones I got are too big. Thanks
PC/SR is offline   Reply With Quote
Old 11-20-2019, 03:15 AM   #2
SAJ
SAJ's Avatar
Default Re: Ring gear pins
4 off 6 mm on one car with countersunk heads (for a nice tidy look only) and 4 off 8 mm plain Allen head grub screws on the next car then 6 off 8 mm plain Allen head grubs on a third and fourth car. Three were done on a drill press_flywheel out. The first was done through the starter hole, counting teeth to keep it balanced.
Lengths all the exact width of the ring gear to just bottom on the flywheel ledge.
SAJ in NZ
SAJ is offline   Reply With Quote
