08-15-2015, 10:40 AM | #1 |
1932 V8 radiator
Near impossible to find an original so anyone have any experience with a good aftermarket replacement? How different, besides the inlets on the tanks, were they from a 4 cylinder?
08-15-2015, 10:48 AM | #2 |
Re: 1932 V8 radiator
I think I saw one on that auction site,not cheap .Good originals can be about $750 +.The V8 upper and lower tanks are totally different than a 4cyl. Try a Walker or US Radiator.
08-15-2015, 11:01 AM | #3 |
Brassworks will build you one anyway you want it. The one I had made for my 33 was excellent quality. Not cheap (and that is an understatement) but you get what you pay for.
http://www.thebrassworks.net/ http://www.thebrassworks.net/shop/Re...13617626c659e1 http://www.thebrassworks.net/shop/Re...430945ce91e40b They specifically call out the B model on the 32 radiators. They also restore an existing radiator. Last edited by JSeery; 08-15-2015 at 11:09 AM. |
08-15-2015, 11:18 AM | #4 | |
Don`t get me wrong and I see the value in original parts but... |
08-15-2015, 11:51 AM | #5 |
Lots a Deuce guys in the Nortwest.Check with V8 Club members .A major collection up there just sold a few weeks ago.The family didn't want the stuff.Lets say that you found usable tanks and sides it still would cost a bundle(over $600) to recore it.
08-15-2015, 12:08 PM | #6 |
I had to provide him with the radiator shell for fitting purposes. It is a 4 row, all new radiator that cost $500.00 Works well, Can run up to a 16# cap 530 223-3978 |
08-15-2015, 12:12 PM | #7 |
I came across an original V8 rad at a swap meet last year for about $200 which had the necks converted to smallblock. I am having it re-cored and tank necks relocated for about $625. Keep hunting, they are around.
Paul J. |
08-15-2015, 12:51 PM | #8 |
Anyone have experience with the new Aluminum radiators listed on Ebay?
Price is really good: 150 bucks for a flathead? http://www.ebay.com/itm/1932-Ford-Al...a4ea20&vxp=mtr Last edited by Kahuna; 08-15-2015 at 12:56 PM. |
08-15-2015, 01:55 PM | #9 |
Keep looking, they're still out there.
I found a V8 converted to SBC several months ago for $200. Radiator shop converted it back to stock, pressure tested and tanked it for $100. Cools my 59AB just fine. |
08-15-2015, 02:03 PM | #10 |
Apart from the tank configuration difference cited above, a production version B radiator core has less capacity than the V-8 core. (Finding a service-only high capacity B radiator would likely be a greater challenge than finding a good original V-8 radiator.)
08-16-2015, 01:29 AM | #11 | |
08-16-2015, 08:52 AM | #12 |
Yes I agree get one from Brassworks. It will outlast you and your car.
1928 "A" Phaeton (mid year with many early features) 1933 "V8" Closed-Cab Pickup Truck (originally a Model B, 4 Cylinder dating to May, 1933)
08-28-2015, 12:46 PM | #13 |
Found an original
08-28-2015, 03:11 PM | #14 |
Remember that the 4 cylinder and V8 radiators use different length radiator support rods.
Charlie Stephens |
08-28-2015, 03:30 PM | #15 |
I did not know that Charlie. Which are longer ?
08-28-2015, 03:39 PM | #16 |
The B rods are 30.25" long and the V-8 rods are 29.60" long.
08-28-2015, 03:49 PM | #17 |
Thanks David and looks like I can trim my B rods
08-28-2015, 05:04 PM | #18 |
08-28-2015, 05:57 PM | #19 |
08-28-2015, 07:03 PM | #20 |
Be suspicious of any "rebuilt" radiator offered for less than $500, particularly if the seller demands payment up front.
08-28-2015, 07:50 PM | #21 |
08-28-2015, 09:15 PM | #22 |
Take a close look before you trim. I think you will find that there is not enough threads on the rods before they go to a smaller diameter to let the nut slide over the rod. Kind of hard to visualize unless you are looking at one.
Charlie Stephens |
08-29-2015, 11:06 AM | #23 |
Charlie,
With respect, the diameter of the rods is 5/16" until the 3/8" threads under the head of the rod at the firewall end. A 3/8-24 nut slips easily over the 5/16" diameter portion of the rod. |
08-29-2015, 11:58 AM | #24 |
That is what I found out as well when taking a closer look at it. With it being a commercial vehicle, rods are not stainless.
08-29-2015, 12:25 PM | #25 |
They weren't originally stainless on any Ford of the era.
08-29-2015, 12:27 PM | #26 | |
What I was trying to say is that the 3/8 threads at the front near the radiator don't go far enough towards the rear of the car before dropping to the 5/16 rod diameter to allow you to cut off the rod. Looking again, it may be close and these threads may have extended further back on some rods. Charlie Stephens |
