03-18-2019, 07:41 PM | #1 |
Commerical Head lights
I'm building a 30 CCPU and have a friend that has a pair of these head lights.
What's the difference? Thank you for your time Terry aka dirt t |
03-18-2019, 08:11 PM | #2 |
Re: Commerical Head lights
Although some 1930 CCPU owners like to "dress up" the pickup by using passenger car stainless steel 1930-31 headlamps, the factory commercial issue was a painted black headlamp shell with the same stainless rim to hold the lens as the passenger car had.
03-18-2019, 08:36 PM | #3 |
And since the CCPU didn't have cowl lights each reflector had places for 2 bulbs (like the standard passenger cars).
Charlie Stephens |
03-18-2019, 08:46 PM | #4 |
And, the commercial headlight buckets are not stainless steel.
03-19-2019, 08:52 PM | #5 |
There are stainless shells out there that were factory painted black. I have seen 2 pairs.
03-20-2019, 09:02 AM | #6 | |
For the 28-29, imperfect plating was a reason to relegate parts to the commercial line - painted black to cover the imperfection. And, IIRC, the black wiring "conduit" were only used on 1930 & beyond AA production, and not even all of that. Joe K
Shudda kept the horse. Last edited by Joe K; 03-20-2019 at 09:11 AM. |
04-09-2019, 08:10 PM | #7 |
And you know they were factory painted how?
1921 Runabout 1930 Tudor Early 1930 AA Speed costs money. How fast do you want to go? |
04-16-2019, 09:52 PM | #8 |
The shells are unpolished stainless. The stainless virgin cross grain has never been buffed out. The shell is painted black over the stainless. the black paint is "under" the riveted bracket. |
03-19-2019, 09:04 PM | #9 |
blacklites and rad shell looks gooder on a pu
03-21-2019, 08:00 AM | #10 |
When I got my 30 Pickup, changed the Stainless headlight buckets, radiator shell, to black, along with fabric conduits, Although many trucks have Cowl Lights,and stainless headlight buckets and radiatiator shell, I guess each there own likes.
03-20-2019, 02:29 PM | #11 |
I have a pair of 1930 Commercial headlight buckets. Unfortunately right now I can only put my hands on one of them.
04-08-2019, 08:11 PM | #12 |
Thank you for the replies.
Terry aka dirt t |
04-09-2019, 03:57 PM | #13 |
You didn't ask but here's a little more 30-31 pickup info. Taillight bucket, radiator shell and cowl band also are painted black. All are plain steel, not stainless, although the taillight has a stainless rim same as passenger. The shell is straight across the top below the badge - doesn't have the "widow's peak" like passenger. AFAIK, the badge and crank-hole cover are the same as passenger.
Seems most pickups have been "upgraded" with bright passenger parts - so much so that the painted commercial parts are hard to find. |
04-09-2019, 04:30 PM | #14 | |
Charlie Stephens |
04-09-2019, 06:50 PM | #15 | |
Right you are. I even started a thread on it a while back (https://www.fordbarn.com/forum/showt...ghlight=pickup) and still got confused - hey, I'm old! It also should be noted this applies to trucks after the mid-30 changeover from the 28-29 style. Thanks for the correction. |
04-09-2019, 06:32 PM | #16 |
Right On Charlie. Correct advice...
04-16-2019, 09:54 PM | #17 |
It’s hard to tell in photo but the stainless has never been buffed.
04-16-2019, 10:06 PM | #18 |
Someone said the cowl band on a 30-31 commercial is painted black. Would that be true for a Panel truck 1931???
Bob from Northport Northport, Michigan |
04-17-2019, 10:57 AM | #19 |
The Standards say it was painted body color but deluxe models would be stainless.
