05-28-2017, 03:03 PM | #1 |
One piece modern Front seal Vs. Rope seal 8BA
Having a hard time getting the original spiral groove spacer off and the new solid spacer is loose. Does the solid spacer compress when the front pulley is mounted? other wise it would spin on the crank.
05-28-2017, 03:27 PM | #2 |
Re: One piece modern Front seal Vs. Rope seal 8BA
I bought the replacement 1 piece seal from Speedway several years ago. When I looked at it in comparison to the recesses in the timing cover and pan, it just didn't look right. I think the solution was to use lots of RTV. I decided to go with a regular rope seal and I'm glad I did, because it has not leaked ANY in the last two years. There was a gauge for cutting the seal properly "proud", a special knife, and instructions I followed to a "T" in the seal kit I had.
That being said, I think I have heard the the seals currently available from some sources are a much better fit and don't need as much sealant, if any. Perhaps someone else had had experience with the later seal and will chime in here. Also, I have also wondered why the sleeve needs to be replaced. The spiral pulls oil into the engine and should function the same no matter what seal is being used. |
05-28-2017, 05:15 PM | #3 |
