01-29-2022, 04:55 PM | #1 |
Columbia 46 ford
Should the inside of vacuum cannister for the columbia rear end have a lubricant on the walls or just apply a light grease or lubricant to the rubber/leather plunger. Thought this may be good idea for sealing and easier movement for the plunger.
Thanks! |
01-29-2022, 11:51 PM | #2 |
Re: Columbia 46 ford
Marvel Mystery Oil works great also 3 in 1 oil is good.
01-30-2022, 11:06 AM | #3 |
Whatever it is must be light and slick I soak the leathers in ATO
01-30-2022, 03:27 PM | #4 |
I was told to use Marvel Mystery Oil. It has worked well for me.
01-30-2022, 05:05 PM | #5 |
Use marvel mystery oil.I have been using this for years.It is what Jon Conelly recomends. And he is the Columbia guru.
01-30-2022, 05:11 PM | #6 |
