Old 12-19-2023, 11:50 AM   #1
Seth Swoboda
Seth Swoboda's Avatar
Default 1937 Halogen headlight conversion
I want to do a halogen headlight conversion on my '37 Tudor. Dake sells a kit with reflectors, sockets/pigtails, and bulbs. However, they are out of stock at least through the end of 2024. Does anyone know of any other sources for these?
Old 12-19-2023, 12:31 PM   #2
terry
Default Re: 1937 Halogen headlight conversion
Try Ron Francis Wiring. I have an old catelog but can't find it. terry
terry is offline   Reply With Quote
Old 12-19-2023, 02:21 PM   #3
Zeke3
Zeke3's Avatar
Check with Michael at Third Gen or some of the other Drake dealers to see if they still have any of the conversion kit.
Zeke3 is offline   Reply With Quote
Old 12-19-2023, 02:47 PM   #4
Newc
Newc's Avatar
Remember this kit will pull a lot of amps -current. Some components can't handle the amperage draw. Newc
Old 12-19-2023, 02:58 PM   #5
Seth Swoboda
I'd probably have to go with a powergen generator.
Old 12-19-2023, 03:09 PM   #6
Fritz
Fritz's Avatar
If it doesn’t come with relays, you should add them to help out your switches with the amps. They’ll make sure your lights are bright too.
Cars and metal rust away and are destroyed, but the Word of God will stand forever (Isaiah 40:8, Matthew 24:35).
Fritz is offline   Reply With Quote
Old 12-19-2023, 03:25 PM   #7
aussie merc
aussie merc's Avatar
just curios why not leds lot less current draw
aussie merc is offline   Reply With Quote
Old 12-19-2023, 05:35 PM   #8
Seth Swoboda
I have ordered two sets of LEDs. None of the two contacts on the back of the bulb line up with the original Ford socket. In other words, they don't make contact. If you are familiar with these bulbs they only go in one way.
Is there something I'm missing with the LEDs because they are the cheapest and easiest way to go about this.
This is a daily driver car. I do drive at night. Well not the '37 because the original bulbs are not bright enough for safe driving.
Old 12-19-2023, 06:42 PM   #9
my4dv8
Good old back order Bob again . There are conversions on eBay ,but as to quality?
my4dv8 is online now   Reply With Quote
Old 12-19-2023, 08:03 PM   #10
ndnchf
ndnchf's Avatar
I don't know what kind of bulb a '37 takes. But after trying ill fitting LED bulbs off ebay for my '35 Fordor, I ordered a pair of flanged LED bulbs from ledlight.com. They fit perfectly and light up the road very well. I can now run my stock 6v generator at a very low setting and still show a positive charge with the lights on. A great cimbination.
ndnchf is offline   Reply With Quote
Old 12-19-2023, 08:15 PM   #11
petehoovie
petehoovie's Avatar
Old 12-20-2023, 09:14 AM   #12
Seth Swoboda
I have ordered from ledlight.com before and they did not fit the '37 bulb socket.
Old 12-20-2023, 11:09 AM   #13
ndnchf
ndnchf's Avatar
Sorry to hear that. Not sure what the difference is. BTW, there are two very similar websites/companies that often confuse people.
Ledlight.com
Ledlights.com
Steve
Old 12-20-2023, 12:24 PM   #14
mark180
mark180's Avatar
I had halogen bulbs in my ‘37 when I inherited it. I switched back because the light scattered all over. I found out later that there are lenses just for the halogen lights that do not have the prisms in them. They might work better than the standard lenses.
mark180 is offline   Reply With Quote
Old 12-20-2023, 04:07 PM   #15
Ken/Alabama
Ken/Alabama's Avatar
I had an original pair of reflectors nickel plated then sent them to a company in Oregon called Uvira. They do reflective coatings and they turned out very nice and way more durable and cheaper than silver. These were for my 39 Zephyr still 6 volt system. Had bright white headlights with original bulbs.
Old 12-20-2023, 04:08 PM   #16
petehoovie
petehoovie's Avatar
Originally Posted by Ken/Alabama View Post
I had an original pair of reflectors nickel plated then sent them to a company in Oregon called Uvira. They do reflective coatings and they turned out very nice and way more durable and cheaper than silver. These were for my 39 Zephyr still 6 volt system. Had bright white headlights.
Old 12-20-2023, 05:44 PM   #17
meric42
meric42's Avatar
Agreed, I have fitted period relays to my cars. I know that it protects the switch & wiring from burning out and, as stated above assures the brightest of lighting from the bulbs. My '42 Sedan had lights equal to or better than most modern cars with its 6Volt halogen bulbs in semi-sealed beam units. and no need to convert to 12 volts either.
I need an 01A 1453 Brkt Spare wheel hold down for my sedan delivery - PLEASE HELP
Gotta love my '42 Sedan Delivery's - Now that I own the only two in New Zealand
https://www.fordbarn.com/forum/album.php?albumid=580
meric42 is offline   Reply With Quote
Old 12-21-2023, 03:48 PM   #18
Fritz
Fritz's Avatar
My experience exactly, meric42.
I don’t trust LED bulbs to last or have consistent quality. Too many have failed me of home and antique auto use. I also prefer the color of halogens/light bulbs and beam pattern than the bluer LEDs.
Old 12-21-2023, 04:02 PM   #19
Bob C
The parts book show 1935-39 use the same headlight bulb.
Bob C is online now   Reply With Quote
Old 12-21-2023, 06:20 PM   #20
40cpe
40cpe's Avatar
My '38 came to me with the Drake halogen conversion (12V). Although not as bright as LED, they match the prism in the lenses and work fine for my limited night driving.
40cpe is online now   Reply With Quote
