Old 01-08-2011, 09:55 AM   #1
georgewarren
Default 523 HP Y-Block!
Check out the Feb 2011 issue of Popular Hot Rodding's engine shoot out. 375 CI Y-block, 523 HP @6500 rpm, 477 ft/lbs @ 4,900 rpm. Uses Mummert alum. heads; when did these come out? Anyone have info or website for these?
georgewarren is offline   Reply With Quote
Old 01-08-2011, 11:47 AM   #2
Ole Don
Ole Don's Avatar
Default Re: 523 HP Y-Block!
ford-y-block.com
Also, in that PHR article, copy down the name of the guy who ram rodded the test. Ted Eaton is a guru who will help any dedicated Y blocker with just a phone call. If you are interested in these heads, you need to subscribe to the Y Block Magazine also. A wealth of exciting information.
Ole Don is offline   Reply With Quote
Old 01-10-2011, 10:04 PM   #3
Noswal
Mummert's website
www.ford-y-block.com
You can see the heads and other y-block performance goodies, and besides that he is a super nice guy. Like Ted Eaton, he will help any y-blocker with advice or recommendations.
Noswal is offline   Reply With Quote
Old 01-11-2011, 02:00 AM   #4
Fairlane500
Fairlane500's Avatar
If you have a look on the Y blocks forever website there is a section there on them that has a lot of information, makes a good read. It has been a long road but they got there in the end with sheer determination.
http://www.y-blocksforever.com/forums/Forum11-1.aspx
Life is not a dress rehearsal...
Fairlane500 is offline   Reply With Quote
Old 01-27-2011, 09:39 AM   #5
A Chopped Coupe
A Chopped Coupe's Avatar
The last Y I helped build certainly fell short of making that kind of HP, but did manage 383HP @ 6000rpm. I am no guru but cam/head/valve train design are certainly the key to making a Y block run. Here are some of the parts that went on the Y block I worked on.
Let's see, $2150 for the heads and $650 for the roller rockers..$2800..that's coming pretty close to what I paid for the Roush/Yates heads on my 408 stroker which flows 371 on the intake side and 294 on the exhaust.
Making over 500HP in any natrually aspirated motor takes cubic $$$$$ and a lot of thought, but in a Y block that is outstanding!
A Chopped Coupe is offline   Reply With Quote
Old 01-27-2011, 07:14 PM   #6
Ralph Moore
Ralph Moore's Avatar
Speed is just a question of money, How fast do you want to go?
Ralph Moore is offline   Reply With Quote
Old 01-28-2011, 02:51 PM   #7
Hot Rod Reverend
Hot Rod Reverend's Avatar
That looks like the makings of a nice build. I am interested in where you got your timing set, is that rollmaster?
thanks, Dan
Lancaster, California
Visit hotrodreverend.com to view hundreds of pictures and videos of the build of the 1955 Ford Club Sedan!
Hot Rod Reverend is offline   Reply With Quote
Old 01-28-2011, 10:44 PM   #8
A Chopped Coupe
Yes, it was a Rollermaster. They make some fantastic parts in Australia.
It was a CS-4060 and even looked better in person than the photograph and the quality was far superior to anything made in the USofA!
http://www.romac.com.au/
